need help...interior lights
Old Feb 20, 2004 | 03:15 PM
munday's Avatar
munday
Default need help...interior lights
here is my setup on my 79. I have autometer guages for speedo/tach and a water/trans temp on the pillar. I am using the included autometer lights that plug in the back. They are grounded to the frame and for the power I spliced into the grey wire on the wiring harness for the stock tach/speedo. The grey wire only supplies power when the light switch is on. It has worked for some time now. When I went to put the speedo/tach back in, I tested the lights and they didn't work. My headlights still work. My running lights still work. On my headlight switch I have power and a good ground. I have narrowed the fault to between the grey wire on the speedo/tach harness and the green wire on the headlight switch harness. I can't find a fuse diagram, the one I have in my chiltons is not the same harness. So I pulled all fuses but the 75amp one. They all seemed good. I did notice there is some surface corossion on the fuse connections, but it has not cause a problem yet.
I can't figure out what to do..both harnesses are good and I can't find a blown fuse. Also it no longer goes "ding ding ding" when the lights are on and the car is not. It stopped dinging at the same time the interior power loss occured.
it sounds like a fuse, but with none being blown..i'm just not sure. the interior lights wire turns from grey to green at the fusebox
[Modified by munday, 2:28 PM 2/20/2004]
Old Feb 20, 2004 | 03:35 PM
Crash80's Avatar
Crash80
Default Re: need help...interior lights (munday)
This sight has some really good schematics that you might find useful. I just got done downloading and printing every last one of them. Good luck!
http://iotech.no/corvette/index.htm
Old Feb 20, 2004 | 03:41 PM
munday's Avatar
munday
Default Re: need help...interior lights (CVT4ME)
cool thanks.
okay I went back out and I used my multimeter and used the beep beep feature and the contact from grey to green is good. So it should not be a fuse.
Old Feb 20, 2004 | 05:05 PM
munday's Avatar
munday
ttt
Old Feb 21, 2004 | 11:20 PM
munday's Avatar
munday
come on guys and gals i need you, i really can't figure this out.. no blown fuse..connection from green to grey is good.... headlights still come one...no ding ding anymore..interior lights don't work on center console and speedo/tach
To need help...interior lights
