dry sump pump does fit
Old Feb 22, 2004 | 08:59 AM
Twin_Turbo's Avatar
Twin_Turbo
Default dry sump pump does fit
My pump does fit without notching the frame, I spaced the pump forward to clear the motor mount and then I checked it on my frame with the mock up block. Plenty of clearance on the front crossmember and the a arm mounts:
Old Feb 22, 2004 | 09:47 AM
Pete79L82's Avatar
Pete79L82
Default Re: dry sump pump does fit (Twin_Turbo)
Edit: Sorry I read your post too quick and thought it said the pump doesnn't fit. I need to get new glasses.
Marck:
You need to purchase/fabricate a riser block to move the pump up the block. Here is a picture of one for a Moroso pump. It would be different for your SCP/Weaver pump but you get the idea of what it does. They are eay to fabricate. Just a block of steel with 2 holes to mount to the block and 2 new holes to mount the pump, moving it outward and upward to get the clearence you need. Belts come in every 1 1/2 inch lenghts from 22" to 29" so you will be able to find the correct length for the new mounting position.
PS: Don't you think a 5 stage system is just a little overkill? :lolg:
[Modified by Pete79L82, 8:53 AM 2/22/2004]
Old Feb 22, 2004 | 10:01 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: dry sump pump does fit (Pete79L82)
Nope, because I have to scavenge a little sump for the turbos too, hence the 4th suction stage :)
Old Feb 22, 2004 | 10:34 AM
Pete79L82's Avatar
Pete79L82
Just courious about the sump for the turbos. Any of the motors I have had on the dyno with turbos just had the drainback lines as a gravity feed back to the pan. What is the need for a seperate sump?
Pete
Old Feb 22, 2004 | 11:32 AM
comp's Avatar
comp
KEEP INFO AND PICS COMING!!!!! :thumbs: :thumbs: :thumbs:
Old Feb 22, 2004 | 11:44 AM
Twin_Turbo's Avatar
Twin_Turbo
I have it like that on my wet sump system but I don't have enough room so I little seperate sump with a breather on top is much easier than hacking up the stefs pan for 2 drains under an angle.
Old Feb 22, 2004 | 03:21 PM
norvalwilhelm's Avatar
norvalwilhelm
Marck running a dry sump is something that I have often thought about, especially when that big red warning light comes on while launching hard.
I already have 3 belts comming off the crank and I don't know if I have room for another.
Old Feb 22, 2004 | 03:33 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: dry sump pump does fit (norvalwilhelm)
I have 3 belts on the crank too, my lower pulley is a 3 groove but it's modular, you can add or remove the pulleys (which are basically 2 halves with shims for proper belt width)
Then there's a little drive mandrel way on the front for the dry sump pump.
Old Feb 22, 2004 | 03:40 PM
norvalwilhelm
I have a big toothed hollow pulley out front for the 3 inch drive belt on the blower.
Old Feb 22, 2004 | 04:26 PM
Twin_Turbo's Avatar
Twin_Turbo
oh yeah, that spells problems :)
To dry sump pump does fit
