76 auto to stick conversion - first steps
Old Feb 22, 2004 | 11:04 AM
bigjoepos's Avatar
bigjoepos
Default 76 auto to stick conversion - first steps
Just starting to take inventory of what is needed to convert my automatic to stick....decision on trans and rear gears to come later...now just trying to get a handle on feasibility....for starters......the automatic frame does not have the bracket support on the frame for the clutch z bar. Is having one welded on the only option? Anyone with some experience with this step? How much trouble to get it positioned correctly?Can a welder get in there? Also, will my automatic cross member work? ... Thanks, bigjoepos
Old Feb 22, 2004 | 12:55 PM
dman535's Avatar
dman535
Default Re: 76 auto to stick conversion - first steps (bigjoepos)
Auto crossmember will work. Consider doing a hydraulic clutch assembly, your left leg will appreciate it in traffic.
Old Feb 22, 2004 | 01:14 PM
norvalwilhelm's Avatar
norvalwilhelm
I converted my 75 from automatic to standard and any hydraulic clutched camaro bellhousing will work. It has the slave cylinder on the side. As for a hydraulic master on your car I found the 85 one ton truck with only a linkage change bolted right up to the existing holes.
To me the hardest part of this swap is installing the pedal assembly. Find a good assembly can also be difficult. The steering wheel must come out and also remove the drivers seat.
Good luck
Old Feb 22, 2004 | 01:16 PM
John 65's Avatar
John 65
On my 80, even though it was an auto from the factory, they all came off the line with 2 holes in the frame, allready tapped to accept the tower for the z bar. I simply bolted it on. You may want to consider this route, just pick one up for an 80, drill 2 holes and run a tap thru them. I would not drill or weld anything till you have the z bar handy to make sure its at 90 degrees from the ball stud in the block.
Old Feb 22, 2004 | 02:11 PM
pillowmeto's Avatar
pillowmeto
Default Re: 76 auto to stick conversion - first steps (John65,80)
:lurk:
want to do the same this summer so im learning more little tricks
MAtt
Old Feb 22, 2004 | 03:24 PM
norvalwilhelm
Default Re: 76 auto to stick conversion - first steps (norvalwilhelm)
Why would anyone want to run mechanical linkage? It interfers with the heads, binds when under extreme load and is outdated. The new hydraulic systems are easy to install, leaves all the room you want for the exhaust and pedal travel is so smooth. They also bolt directly to our fire wall, the holes are already drilled.
Old Feb 22, 2004 | 04:40 PM
bigjoepos's Avatar
bigjoepos
Well that was interesting....I like the sound of hydraulic system.....I guess the camaro bell route sounds like a good fix if I go with a 4 speed...........I am tempted to mix it up a bit with a 5 speed......but that is the next string of messages.....Thanks for the info...I am new to CF and this was my virgin posting.....BJP
To 76 auto to stick conversion - first steps
