Is 16" big enough?
Old Feb 22, 2004 | 11:18 AM
74FLCONV's Avatar
74FLCONV
Default Is 16" big enough?
I'm switching to an electric fan and would like to know if a single 16" hi-flow (2800 ~ 3300 cfm) fan is adequate. Car is stock 350, auto, AC (which never gets used) with new (original) radiator.
Thanks in advance,
D. Ocean
Miami, FLA
Old Feb 22, 2004 | 12:03 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Default Re: Is 16" big enough? (74FLCONV)
Oops...sorry...thought you were asking about a different 16 incher. I can't give advice on the fan. ;)
Dep
Old Feb 22, 2004 | 12:15 PM
74FLCONV's Avatar
74FLCONV
Default Re: Is 16" big enough? (DJ Dep)
:rolleyes:
Right...mine's only 3", but some girls like 'em that wide.
So...16" fan or not?
D. Ocean
Miami, FLA
Old Feb 22, 2004 | 12:20 PM
DJ Dep's Avatar
DJ Dep
Danny: I like your style ;)
What diameter is the original? Florida gets pretty hot and you don't want to undercool it. With fan, shroud, and thermostat switch, I'd think it would be allright. Still wouldn't want to get stuck in traffic on a hot day. Especially without AC!!!!
Dep
Old Feb 22, 2004 | 11:35 PM
74FLCONV's Avatar
74FLCONV
The stock fan is less than 16", but I think it pulls more air than an electric. I've seen some set-ups here with a single electric fan, but I haven't been able to find those threads with "search".
:confused:
D. Ocean
Miami, FLA
Old Feb 22, 2004 | 11:46 PM
DJ Dep's Avatar
DJ Dep
This is the only thread I found:
http://forums.corvetteforum.com/zerothread?id=461264
dep
Old Feb 22, 2004 | 11:53 PM
74FLCONV's Avatar
74FLCONV
Yep...it seems everyone with an insane engine is running dual Spals or Flex-a-Lites. However, I'm wondering if my ground-thumping, window rattling 195 BHP SB also needs duals. There's a big difference in price between a nice hi-flow 16" and duals.
And furthermore...there is NO FREAKIN' WAY I'm going to wrestle that stock fan shroud back in position. I'll convert the entire engine to electric before I attempt that again.
D. Ocean
Miami, FLA
Old Feb 22, 2004 | 11:56 PM
DJ Dep's Avatar
DJ Dep
Personally, I will be running a factory fan/clutch on my big block. And the shroud may be a pain in the butt, but it DOES work good. Remember, even the L-88 used a standard fan/clutch and it was pretty wild.
Dep
[Modified by DJ Dep, 8:01 AM 2/23/2004]
Old Feb 23, 2004 | 12:02 AM
74FLCONV's Avatar
74FLCONV
OK. I'll pay your way to FLA and YOU put the ***** back on.
D. Ocean
Miami, FLA
Old Feb 23, 2004 | 01:14 AM
mrvette's Avatar
mrvette
I have an '87 vette main fan in the basic puller position mounted in the stock stroud, BUT, and here is the cool part....I split the shroud into a top and bottom halfs, that makes it way much easier to get in and out....I also moved the fan far forward in the install as possible and keep the shroud functional....and also cut the depth of the shroud down much as possibel...getting rid of that 18 inch diameter 'wind tunnel' the original fan was in....this makes the entire engine much easier to work with/on....
any sort of temp switch can work for activating the stock GM fan relay....
it's basically a bolt in swap with a bit of creativity...I am getting ready to mod that entire setup once again in my car though, as I have a spreader bar, and want to install that, need clearance on the fan....
GENE
Old Feb 23, 2004 | 09:04 AM
DJ Dep's Avatar
DJ Dep
Default Re: Is 16" big enough? (mrvette)
GENE: That's a great idea on the split shroud!!! :thumbs:
Dep
Old Feb 23, 2004 | 09:12 AM
groovyjay's Avatar
groovyjay
Wasn't SIGNGUY just working on this?! :cheers:
Old Feb 23, 2004 | 09:42 AM
Stoge's Avatar
Stoge
Default Re: Is 16" big enough? (groovyjay)
:iagree: :yesnod: :yesnod:
Old Feb 23, 2004 | 12:19 PM
Fevre's Avatar
Fevre
I did exactly what Gene did, split the shroud in half, that is until I tossed the whole thing in favor of dual Flex-a-lites.
Old Feb 23, 2004 | 12:39 PM
78 Vette's Avatar
78 Vette
Default Re: Is 16" big enough? (Fevre)
I run duel Be Cool fans in my 67 Nova (steel head 600 hp 462) They work great they should turn your motor into a ice cube :thumbs: . My experience is one clutch fan is usually better than 1 electric fan but 2 electric fans are way better then 1 clutch fan. I run a 7 blade with a 70 454 clutch and a be cool rad with a 180 therm in my Vette.
To Is 16" big enough?
