What is this little pipe?
Old Feb 22, 2004 | 06:18 PM
leeloo67's Avatar
leeloo67
Default What is this little pipe?
I found this today. It was wedged between lines at the bottom of the engine compartment, right next to the lower radiator hose. It has a fitting similar to a fuel fitting (rounded off by someone as you can see). The previous owner had replaced the entire brake system, including the metal lines. Is this an old brake line part? I couldn't match it up with anything on the car...
Old Feb 22, 2004 | 06:24 PM
stpman's Avatar
stpman
Default Re: What is this little pipe? (leeloo67)
Looks like a trans cooling line from the radiator
Steve :steering:
Old Feb 22, 2004 | 06:25 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
looks like the connection to the tranny oil cooler on the radiator.
Old Feb 22, 2004 | 06:26 PM
AKRAY4PLAY's Avatar
AKRAY4PLAY
looks like the tranny cooler return line fitting. do you have an automatic?? auto tranny coolers plumb in right in that area, and it common for people to strip the treads from not using a tuing wrench. Brian
Old Feb 22, 2004 | 08:37 PM
1FUNVET's Avatar
1FUNVET
Default Re: What is this little pipe? (AKRAY4PLAY)
In case ya didn't get it the first three times, DITTO!! :thumbs:
Old Feb 22, 2004 | 09:31 PM
Jack71's Avatar
Jack71
Default Re: What is this little pipe? (1FUNVET)
I think it looks like a battery... AA most likely.
Old Feb 22, 2004 | 09:47 PM
Stoge's Avatar
Stoge
I knew I've seen that part somewhere before. I agree that is a fitting for the return line on the radiator for your trans cooler.
By the way, could you please post your sig pics top & bottom instead of side by side? It is making a lot of us 800 X 600 viewers have to scroll a_whole_bunch to read your post. Not trying to be a PITA, but just a heads-up.
:cheers:
Old Feb 22, 2004 | 10:05 PM
SLine78's Avatar
SLine78
That pipe could have screwed into rear of the base of the carburetor to supply the hose connection for the vacuum to your power brake booster.
Mike
Old Feb 23, 2004 | 01:23 AM
munday's Avatar
munday
Default Re: What is this little pipe? (SLine78)
thats the bubba energizer, commonly duct taped to the battery line as a capacitor for when his 8" optima subs are hitting off the 50 watt equilizer
Old Feb 23, 2004 | 02:13 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: What is this little pipe? (Jack71)
:lolg: :lolg: :lolg: :lolg: :lolg:
Old Feb 23, 2004 | 02:26 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
A Crack Pipe ?!?!?!
Where has this car been when You havn`t been looking???
:lol: :lol: :lol: :lol:
Old Feb 23, 2004 | 03:06 PM
AV8RSVT's Avatar
AV8RSVT
Default Re: What is this little pipe? (12stepvette)
:crazy: :crazy: :crazy: :crazy:
To What is this little pipe?
