WILL IT FIT?
Old Feb 23, 2004 | 08:20 AM
wadey's Avatar
wadey
Default WILL IT FIT?
JUST BOUGHT A NEW HOLLEY FUEL PUMP (MECH.), 110 GPH AND WAS WONDERING
IF THERE ARE ANY CLEARANCE ISSUES WHEN SWAPPING OUT MY STOCK
PUMP. CAR IS IN STORAGE SO I CAN'T CHECK IT OUT UNTIL SPRING.
MY CAR IS A '76. THANX WADE
Old Feb 23, 2004 | 01:15 PM
wadey's Avatar
wadey
Default Re: WILL IT FIT? (wadey)
ttt
Old Feb 23, 2004 | 01:53 PM
Fevre's Avatar
Fevre
I installed a Holley strip pump once not knowing it was the strip version and it fit OK but was tight. I think both the street and strip pumps have bases that can be rotated to align the inlet/outlet. Neither pump has a return line provision. I ended up just buying a stock replacement pump since the strip pump was too high in pressure and did not care for the added clutter of a pressure regulator.
Old Feb 23, 2004 | 03:13 PM
LOTAHP's Avatar
LOTAHP
Default Re: WILL IT FIT? (Fevre)
Mecanical Fuel Pump swap out... You sould have NO problems. :thumbs:
To WILL IT FIT?
