Quick question, about auto trans, cooling lines
Old Feb 22, 2004 | 08:12 PM
randy814u's Avatar
randy814u
Default Quick question, about auto trans, cooling lines
I noticed I had a leak, and traced it to a rubber hose that comes off the end of the cooling line at radiator, and goes to a short line coming out of radiator.
Kinda looks like a splice to me. So my question is, are the lines from trans to the radiator all one piece metal, or did they come factory with the rubber splice in it?. I could not find anything in the assembly manual. Thanks, Randy
for a 78
Old Feb 22, 2004 | 08:16 PM
stpman's Avatar
stpman
Default Re: Quick question, about auto trans, cooling lines (randy814u)
They came with the rubber hose. both my 73 and 74 are like that
Steve :steering:
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
These rubber lines are from the factory-your's may have been changed or may not have been changed, but, yes, the factory DID use rubber hose connections here.
Old Feb 22, 2004 | 08:18 PM
1979toy's Avatar
1979toy
The rubber section is to acount for chassis flex. Both the inlet and the return lines should have a section of rubber hose. When you go after replacement hoses be sure to tell the auto parts person that the hose is for a transmission line.
Old Feb 22, 2004 | 08:19 PM
randy814u's Avatar
randy814u
Thanks guys, that was quick. I just wanted to know if I should get new hose, or new lines. Always glad the help is here when it is needed.
:seeya
Old Feb 22, 2004 | 08:24 PM
Paul Borowski
Another note-get rid of those stupid ORIGINAL "D" style clamp(mini tower?). They kinda crimp the rubber in one area and cause worse leaks. The best clamps for these are the correct sized "worm gear" as they tighten evenly around the "circumference", rather than "pinching" on one area.
To Quick question, about auto trans, cooling lines
