Electric Cooling Fan
Old Feb 23, 2004 | 05:41 PM
classicguy's Avatar
classicguy
Default Electric Cooling Fan
I sure this has been dicussed befor seached thru topics could not find it though. I just removed the A/C system from my car and was considering lossing the the clutch fan and should. In place i was going to use an electric fan. Would the former electric fan for the A/C when wired correctly be enough to keep the engine cool Note this a stock 82 motor with crossfire if that makes a difference. If not what would anyone recomend doing :auto:
Old Feb 23, 2004 | 06:52 PM
spikezz4's Avatar
spikezz4
Default Re: Electric Cooling Fan (classicguy)
Convert your belts to a serpentine system, then source a 90-96 fan shroud and fans. Replace the electric motors with new GM's, then install. More cooling than after market, all GM parts available, and cools lots of HP, when you decide to upgrade the engine.
Spike
