color dye
Old Feb 24, 2004 | 11:03 AM
vettevirgin's Avatar
vettevirgin
Default color dye
need to dye several dif parts and fabrics on 73 vette has anyone used a particular product with better results? any tips you can give me would sure help thanks
Old Feb 24, 2004 | 12:28 PM
70BBvert's Avatar
70BBvert
Default Re: color dye (vettevirgin)
Just did the black carpet in my Mustang with RIT dye. Worked out great. Haven't tried anything else though. Theses guys have leather dye http://leatherique.com/default.htm
Jim
Old Feb 24, 2004 | 07:09 PM
ductape's Avatar
ductape
Cruise-In V Veteran
OK. No one's listened to me yet, but I'll try again. If you can spray it on yourself, go to the auto paint supply store with the vette code of the color you want and they will mix that very factory color for you. It cost me $60 for a quart. Did everything but the seats. They did not need it. Also sprayed the dash pad. You must use cleaner to get anything to stick for good. Again, the paint shops have the primer(the kind you wipe on) and cleaner. If you don't do this, the dye will fish-eye and later rub off. If you don't care about factory colors, just go to NAPA and use their spray cans. They're good. But you still need to clean and prime. Just my $0.02 :seeya
Old Feb 24, 2004 | 07:48 PM
bjandajatbraves's Avatar
bjandajatbraves
I used zips dye and no sand primer for carpet and vinyl and plastics.
Old Feb 24, 2004 | 08:06 PM
blue427's Avatar
blue427
I've used Tower spray paints with good results.They advertize in Hemmings.Tower Paints,922 Oregon St.,Oshkosh,Wi. 54901.Sorry I don't have the phone# :steering:
To color dye
