Edelbrock Carb Question
Old Feb 24, 2004 | 09:44 PM
Ron 75 L48's Avatar
Ron 75 L48
Default Edelbrock Carb Question
I replaced my Holly with an Edelbrock 4106 on my '75 and now I need to "tweak" it some. It really runs great but when I stomp on it I notice there is definately a difference in the shift duration compared to the Holly. The Edlebrock takes longer to shift than what the Holly did. Is there a link somewhere with documentation on tuning/adjusting the carb for peak performance? The reason I switched to the Edelbrock was I could not get the Holly to stop "perculating" the fuel in the bowls after I shut it down. Even with the heat shield I still had problems. I am running a rebuilt 350 .030 over with a comp xe 268 cam and a TH400 transmission.
Thanks,
Ron
Old Feb 25, 2004 | 10:38 AM
SCCACFC's Avatar
SCCACFC
Default Re: Edelbrock Carb Question (Ron 75 L48)
If the detent cable is to titght it will hold the shift longer and will kick down to early.
Old Feb 25, 2004 | 08:22 PM
Ron 75 L48's Avatar
Ron 75 L48
Default Re: Edelbrock Carb Question (SCCACFC)
I hate to sound stupid but what/where is the detent cable? Are you talking about the throttle cable?
Thanks,
Ron
Old Feb 25, 2004 | 08:37 PM
comp's Avatar
comp
second one ,goes to trans. i'm going to learn to ajust soon
Old Feb 25, 2004 | 09:12 PM
goinbroke's Avatar
goinbroke
Default Re: Edelbrock Carb Question (comp)
Ummmm........can't remember.....did the 75 have a detent cable??.....or was it still the detent switch under the dash.
Old Feb 25, 2004 | 10:52 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Re: Edelbrock Carb Question (goinbroke)
I remember it being a switch, don't know where the switch is though. There was an orange wire coming off my th400 and I think everyone was saying that's the kickdown solenoid wire.
Old Feb 26, 2004 | 07:40 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
the electric switch would only be if it has a turbo 400 auto trans. The turbo 350 uses a cable attached to the throttle linkage.
Old Feb 26, 2004 | 08:09 AM
redwingvette's Avatar
redwingvette
Default Re: Edelbrock Carb Question (SanDiegoPaul)
:iagree: with Paul
The TH400 had a vacuum line from the intake to the modulator valve and a orange wire that went to the kick-down solenoid (down shifting) activated by a switch on the accelerator pedal when fully depressed. Most up-shift problems are caused by a vacuum leak so check for that.
Old Feb 26, 2004 | 11:53 AM
Ron 75 L48's Avatar
Ron 75 L48
Default Re: Edelbrock Carb Question (redwingvette)
Thanks everyone. I don't know why I didn't think about the switch. It is located under the gas peddle. I think I recall that to reset it I need to press the accelerator all the way to the floor to (engine off :D ). I will also look to see if there is a vacuum leak to see if that may be the problem.
Ron
To Edelbrock Carb Question
