Blinker light problem
Old Feb 26, 2004 | 05:34 PM
conway62's Avatar
conway62
Default Blinker light problem
The blinkers work fine until I put on the parking lights or head lights. When I turn on the lights, the LH blinker light stays on. When I turn on the blinker it works ok. Once I turn off the blinker the LH blinker light stays on solid. With the lights off the blinker light is off and the blinker works fine. Any suggestions?
Thanks in advance.
- Ron :hurray:
Old Feb 26, 2004 | 08:58 PM
conway62's Avatar
conway62
Default Re: Blinker light problem (conway62)
Anybody ??
Old Feb 26, 2004 | 09:05 PM
Fleetwood's Avatar
Fleetwood
What year is your vette?Try removing the flasher relay,see if the problem goes away.It could also be an earth fault.
Neil.
Old Feb 26, 2004 | 11:17 PM
wombvette's Avatar
wombvette
Default Re: Blinker light problem (Fleetwood)
Yea mate it sounds more like an EARTH fault at one of the sockets.
Old Feb 26, 2004 | 11:20 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Re: Blinker light problem (wombvette)
wtf is an earth fault?
Old Feb 26, 2004 | 11:27 PM
Fleetwood's Avatar
Fleetwood
Default Re: Blinker light problem (feb18blacksunday)
OK pickie boys GROUND fault.
Old Feb 27, 2004 | 07:42 AM
tersian's Avatar
tersian
I love the Aussies.. EARTH fault, and AL-LOOO-MINIUM hehe
If a "hot" wire contacts a grounded enclosure, a ground fault results which normally will trip a circuit breaker or blow a fuse. Metal enclosures and containers are usually grounded by connecting them with a wire going to ground.
It could also be that you are out of blinker fluid :)
Old Feb 27, 2004 | 10:44 AM
Calm Screamer2's Avatar
Calm Screamer2
You've just described the exact problem in my '82. I replaced the flasher unit just becaues it was cheap and fast to do, but it had no effect on the problem. Let me know what you find.
Old Feb 27, 2004 | 12:04 PM
fjetb's Avatar
fjetb
Default Re: Blinker light problem (Calm Screamer2)
I, too, have the exact same problem on my 71. I look forward to your sharing the solution! :cheers:
Old Feb 27, 2004 | 12:53 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Blinker light problem (fjetb)
http://www.geocities.com/changeyourblinkerfluid/
Old Feb 27, 2004 | 01:06 PM
conway62's Avatar
conway62
Thanks for all the suggestions. The car is a 71 vert. I will try looking at the ground points this weekend and will post what I find
- Ron :hurray:
Old Feb 28, 2004 | 05:47 AM
Fleetwood's Avatar
Fleetwood
Default Re: Blinker light problem (tersian)
I find it hard to believe that you dummies don't know that EARTH fault & GROUNG fault are the same thing :lolg: :lolg:
And by the way tersian we spell aluminium the correct way.
Well thats the last time I help anyone on this Kiddies forum :cheers:
Old Feb 28, 2004 | 09:14 AM
Vmo's Avatar
Vmo
Check the light sockets for corrosion. Probably on the left side. Make sure to pullout the bulb and use a strong light. Once you get it fixed, remember to use bulb grease (dialectric) to prevent reoccurance. Good luck.
Old Mar 1, 2004 | 07:07 AM
Calm Screamer2
Default Re: Blinker light problem (Vmo)
Sounds like a good guess...I'll look into this weekend. Thanks! :cheers:
To Blinker light problem
