Notorious bolts
Old Feb 28, 2004 | 09:14 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Notorious bolts
I am trying to remove the 3 bolts that hold the front caliper brackets and dust shield to the upright. But they are SOLID. Tried 1/2" impact wrench, breaker bar, heat, 1 hr of liquid wrench... nothing. :smash: :smash:
What is the typical PITA factor for these?? Ideas?
Old Feb 28, 2004 | 09:21 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Notorious bolts (Turbo-Jet)
I had the same problem. Finally gave up. figured that if they've been together for 30years+ and wouldn't separate, God wanted it that way. :lol: Only pieces I couldn't get apart on the front end, and I'm a little persistant. :D
[Modified by Jughead, 9:22 PM 2/28/2004]
Old Feb 28, 2004 | 10:01 PM
norvalwilhelm's Avatar
norvalwilhelm
The caliper is held on by a bracket that has 2 through bolts that also hold on the steering arm plus one very large bolt in the top of the spindle. The through bolts can be replaced if you break them. Remember there is a nut on each one. The large bolt in the spindle doesn't have a nut, I would use heat on all bolts but not from a propane torch. You need a good oxy/acetalyne? for quick heat. Douse with water while hot also helps or loosen them hot. An impact doesn't have the torque for a stuck bolt. Then again a 3/4 inch drive impact has alot of torque.
Old Feb 29, 2004 | 12:11 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: Notorious bolts (norvalwilhelm)
my IR 1000 lb/ft half inch tackles most of the bolts I need unstuck. But only after I kroil the heck outta of it..
Old Feb 29, 2004 | 06:14 PM
norvalwilhelm
Default Re: Notorious bolts (88'Cubka)
I don't understand this? What is a IR that produces 1000 Ft/lbs of torque? What is kroil the heck out of it???
Old Feb 29, 2004 | 06:18 PM
Twin_Turbo's Avatar
Twin_Turbo
IR = Ingersoll Rand, 1000lbs.ft impact wrench. Most likely a thundergun :)
As for the upper bolts, you guys DO realize that the dust shield has little tabs on it that bend up to prevent the large nut from coming loose? I didn't have probs with my bolts at all, the 2 through bolts have pinched nuts (self locking) and the upper one came out with a good blow of the impact wrench.
[Modified by Twin_Turbo, 5:21 PM 2/29/2004]
[Modified by Twin_Turbo, 8:54 AM 3/1/2004]
Old Feb 29, 2004 | 07:11 PM
norvalwilhelm
Default Re: Notorious bolts (Twin_Turbo)
Never heard of 1000ft/lbs from a 1/2 inch gun? I jump to a 3/4 inch impact gun if I need it but find a 3 foot breaker bar does more.
As for the upper bolt I install everything with anti seize so it is never a problem.
On of the most used tools in my shop is the wire wheel on a grinder. I polish all threads before installing. I also use copper anti seize generously.
Old Feb 29, 2004 | 07:17 PM
PatsLs1vette's Avatar
PatsLs1vette
yep ingersol rands IR2135TI is a bad gun,i just got a 3/4 inch for work for the big stuff.
Old Feb 29, 2004 | 07:24 PM
Twin_Turbo's Avatar
Twin_Turbo
I do the same thing, of all the things I have the largest collection is most likely wire wheels and wire bristles. I also always clean up the thread and coat with copper paste.
Old Feb 29, 2004 | 08:33 PM
ZD75blue's Avatar
ZD75blue
Why the copper paste? :confused:
Old Feb 29, 2004 | 11:33 PM
R 73 454's Avatar
R 73 454
Default Re: Notorious bolts (ZD75blue)
KROIL..... THE OIL THAT KREEPS! Accept no substitute, hard to find, but worth the search! :smash:
Old Mar 1, 2004 | 04:57 AM
Twin_Turbo's Avatar
Twin_Turbo
Keeps the moisture and road grime out, no rusting bolts, easier to remove.
Old Mar 1, 2004 | 09:05 AM
SharkAttack's Avatar
SharkAttack
Yep, don't forget the tabs. I removed mine with ease several months ago and they had clearly never been removed (circa '72). Tools used were a 1/2" drive 6-point socket and 18" breaker bar.
Old Mar 1, 2004 | 09:54 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Notorious bolts (SharkAttack)
thanks for editing the typo in the quoted section... a fust shield. man I should really get some typing lessons :)
[Modified by Twin_Turbo, 8:55 AM 3/1/2004]
Old Mar 1, 2004 | 09:56 AM
NHvette's Avatar
NHvette
I just popped both my front spindle/knuckle/caliper brackets apart last weekend.
What a (female dog) that was. The BIG bolts at the top come out fairly easily,
since they are tapped into a pocket - and not much rust forms in there.
If you don't have the tabs bent back, you can't even get the wrench on.
MY IR231 (500 ft-lbs) took those out no problem. The through-bolts are what
stopped me cold. Two came loose with the air wrench. The third came loose
after putting a 2 1/2 foot pipe on my ratchet. The last one needed lots of heat
then oil. Then I managed to break a 1/2" drive 3/4" 6point socket in half.
More heat more heat more oil more heat .... new socket ... finally loosened
up.
:seeya
Old Mar 1, 2004 | 10:00 AM
tersian's Avatar
tersian
Default Re: Notorious bolts (R 73 454)
Search no longer :)
http://www.kanolabs.com
Just buy it online... I think other places online carry it cheaper, but it's all good.
Old Mar 1, 2004 | 12:25 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
When I was doing some rear end work on mine, I tried my buddy's 1/2 " air impact to no avail. finally pulled out my electric 1/2' impact and after about 15 seconds of rattlings, they broke free.. I like the electric because the torque is a constant and you dont have to worrk about pressure drop off.
To Notorious bolts
