How advanced is your timing.
Old Feb 29, 2004 | 04:21 PM
motown 71's Avatar
motown 71
Default How advanced is your timing.
I have stock, 350 holly 650 vac. secondaries.
Timing is set at 9deg.advanced I get a slight cough when in 2nd and the rpms get in higher range....just wondered what ya'll are running in terms of advance.
Old Feb 29, 2004 | 04:37 PM
78 Vette's Avatar
78 Vette
Default Re: How advanced is your timing. (motown 71)
Mine is locked at 36.
Old Feb 29, 2004 | 04:48 PM
motown 71's Avatar
motown 71
Default Re: How advanced is your timing. (78 Vette)
Do ya run a little hotter advanced that far ?
Old Feb 29, 2004 | 04:56 PM
norvalwilhelm's Avatar
norvalwilhelm
I would go for about 20 degrees and lock the total to 38 or so all in my 3000. This is from a chevy high performance manual.
I have my bigblock limited to 43 degrees at 3000 and it seems to like this much advance. I do have a retard computer that takes timing away as the boost builds since I am blown.
Old Feb 29, 2004 | 05:26 PM
motown 71's Avatar
motown 71
Default Re: How advanced is your timing. (norvalwilhelm)
Thanks for the input fellas, appreciate it very much
:cheers:
Old Feb 29, 2004 | 05:34 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine is at 40 degrees right now and might try it even higher this is with iron heads and 10:1 CR also get 230 psi in all cylinders when cranking it. :D
Old Feb 29, 2004 | 06:00 PM
Gordonm's Avatar
Gordonm
Default Re: How advanced is your timing. (MotorHead)
Initial is set at 12 and I have 36 total by 3000 rpm. An additional 10 degrees of vacuum when cruising. I tried more advance and it slowed the car down.
Old Feb 29, 2004 | 06:21 PM
CF6873's Avatar
CF6873
Default Re: How advanced is your timing. (Gordonm)
Motown, Their is a very in depth article on setting timing in the tech section. It was written by Lars and will advance your knowledge on the subject. Craig :cheers:
Old Feb 29, 2004 | 07:13 PM
marshrat99's Avatar
marshrat99
Mine is pretty much 79 stock. I've set at 12 in idle, full 36 at 2,500 plus another 10 vacuum. :cheers:
Old Feb 29, 2004 | 07:51 PM
motown 71's Avatar
motown 71
Default Re: How advanced is your timing. (marshrat99)
Thanks all.......I'm headed to the tech article now !!
:cheers:
Old Feb 29, 2004 | 11:25 PM
Eric R's Avatar
Eric R
Last guy I know that did that cracked some forged pistons!
Old Mar 1, 2004 | 12:05 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: How advanced is your timing. (Eric R)
Mine's set at 20 inital, 36 total w/o vac. Some of you guys with 12 initial, why do I not have as much travel in my mechanical advance?? It was been rebuilt and moves freely, and resprung with soft springs to reach max advance earlier.
-Chris
Old Mar 1, 2004 | 12:47 PM
MotorHead's Avatar
MotorHead
Default Re: How advanced is your timing. (RUXperienced)
-Chris
Stock HEI has 15 deg advance built in so to get 36 deg total you set it to 21 deg initial( this is without vacuum advance connected )
My MSD Pro Billet is adjustable I forget what the range is but it allows you to keep whatever you like for intial timing and lets you advance the total timing up or donw if you want. :D
Old Mar 1, 2004 | 01:14 PM
LiveandLetDrive
Ah, that's cool. Well as long as I'm not pinging (one good thing about low compression!) and no heat trouble that somebody else mentioned, is there any reason not to run so advanced? Could I machine out the slot to get more travel or is that going to cause other complications?
-Chris
To How advanced is your timing.
