Clutch pedal neutral safety switch....
Old Feb 29, 2004 | 10:38 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Clutch pedal neutral safety switch....
Can I run the solenoid wire through the switch(open / closed). The wires going through the auto shifters neutral safety switch was 10 - 12 gauge wire. Are the standards the same way?
Anyone got a shop manual on this wiring diagram.
Old Mar 1, 2004 | 08:00 AM
Jim Shea's Avatar
Jim Shea
Default Re: Clutch pedal neutral safety switch.... (Budman78)
The wires in and out of the clutch switch are 12 gage purple. I have a 1971 Chevrolet Service Manual. The circuit doesn't make sense to me since the clutch switch seems to be in a loop. I will need to scan three pages for you today. I just don't have time this morning.
Old Mar 1, 2004 | 09:16 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Default Re: Clutch pedal neutral safety switch.... (Jim Shea)
Thanks, Jim
budman-78@comcast.net
Old Mar 1, 2004 | 09:43 AM
Fevre's Avatar
Fevre
Have mine jumped for a while now, so I can start the car without having to get in and push the clutch, just make you remember that at all times, I forgot to check to make sure it was out of gear ONCE! :(
To Clutch pedal neutral safety switch....
