Carburetor? Please Help!!!
Old Mar 3, 2004 | 11:00 PM
kjsmarty's Avatar
kjsmarty
Default Carburetor? Please Help!!!
Cylinders 2,4,6,8 are not firing! Engine runs very rough with pedal to floor. Exhaust manifold for 1,3,5,7 hot, 2,4,6,8 COLD!!! Coming out of garage kept storage. Ran fine when parked, started few times over Winter. What's up!
Please help Thanks
Old Mar 4, 2004 | 05:18 AM
Mystery Machine's Avatar
Mystery Machine
Default Re: Carburetor? Please Help!!! (kjsmarty)
That don't sound too good! I'm useless but I can give you a bump so someone smarter will see it! :thumbs:
Old Mar 4, 2004 | 06:56 AM
JBR's Avatar
JBR
You are right"that does not sound very good" Do you have spark to the cyl that are not firing? Do you have dual exhaust, if so maybe a mouse nest in one pipe :smash: :cheers:
Old Mar 4, 2004 | 07:38 AM
comp's Avatar
comp
Default Re: Carburetor? Please Help!!! (JBR)
is thats side getting fuel???
Old Mar 4, 2004 | 08:59 AM
page62's Avatar
page62
I'm gonna agree with the mouse nest in exhaust theory. Both primary carb barrels feed both engine banks -- it isn't one barrel per bank. And the ignition doesn't favor one side over the other -- unless wires are cut. Same goes for valvetrain. What's left? Blocked exhaust... :confused:
Old Mar 4, 2004 | 12:00 PM
kjsmarty's Avatar
kjsmarty
Default Re: Carburetor? Please Help!!! (page62)
Thanks for help. Yes- dual exhaust. Could a mouse nest really block exhaust and would it cause no firing on that side of the engine? And are you positive one side of the carburetor (1973 Q-Jet) doesn't fuel just one side of the motor.
Old Mar 4, 2004 | 12:34 PM
Tomi72's Avatar
Tomi72
Could it be a heat riser stuck in closed position :confused:
Old Mar 4, 2004 | 12:52 PM
e3pres's Avatar
e3pres
St. Jude Donor '08-'09
Default Re: Carburetor? Please Help!!! (Tomi72)
That would be my guess.
Old Mar 4, 2004 | 04:08 PM
Willis's Avatar
Willis
A heat riser stuck wouldn't have that effect, more air would just be brought in from the other heat riser Try this, it will take $.99 and twenty minutes, unbolt the carburetor, take the top off and spray some carb cleaner down where the jets are. My guess is that one of your jets is plugged, I had this same problem on my 81.
Old Mar 4, 2004 | 10:46 PM
kjsmarty's Avatar
kjsmarty
Default Re: Carburetor? Please Help!!! (comp)
Spark and fuel at each cylinder 2,4,6,8. No exhaust from that side's dual exhaust.
Old Mar 4, 2004 | 10:56 PM
Shark Racer's Avatar
Shark Racer
Want new mufflers? Saw the tail pipe somewhere so whatever obstruction is there can be blown out...
This is a really messed up problem. I can't wait to hear what the hell is causing it!
-Steve
Old Mar 5, 2004 | 12:26 AM
kjsmarty's Avatar
kjsmarty
Default Re: Carburetor? Please Help!!! (Pacin'California)
Thanks for replying because I'm lost...no mufflers-it's a stainles steel chamberred exhaust-all pipe (tube) Thanks
Old Mar 5, 2004 | 12:46 AM
Shark Racer
If there were anything in the pipe then, it would most likely get blown out. That would have a s***load of force on it and it would get broken up... I think there may be something wrong with the passenger side cylinder head?
-Steve
Old Mar 5, 2004 | 05:23 AM
Tomi72's Avatar
Tomi72
Default Re: Carburetor? Please Help!!! (Willis)
We must be talking about a different thing (probably my bad), on my 72 there is only one heat riser, it's the valve thingy on the passenger side exhaust between the manifold and pipe. When it's closed the exhausts are supposed to run to the exhaust manifold on the otherside through the crossover in the intake and heat it up. The heat riser should open when it warms up.
I'm thinking maybe the heat riser valve is stuck in closed position and perhaps the crossover is a little blocked by carbon?? It could cause bad running I guess.
I don't think it's a carb problem because even if there's something wrong with it the dualplane intake shouldn't leave 2,4,6,8 all without gas.
Old Mar 5, 2004 | 09:56 AM
Willis's Avatar
Willis
You're right we're talking about two different things. My 81 has the two tubes running down from the air cleaner that transfer heat from the exhaust manifolds to warm up the intake air. If one of those valves was stuck closed you probably wouldn't notice a thing.
Old Mar 5, 2004 | 09:58 AM
Willis's Avatar
Willis
I would say run a compression check on that side and see if you have compression, maybe you have some stuck valves/lifters?????
To Carburetor? Please Help!!!
