Cheap method for front ride height adjustment????
Mar 5, 2004 | 07:32 PM
Re: Cheap method for front ride height adjustment???? (turtlevette)
turtle, if you know any parts counter people, ask to look in the back of their shock catalog at the section that gives the specs for their airshocks and see if any come close to what you are looking for. Hershey :chevy
Mar 6, 2004 | 12:36 AM
Re: Cheap method for front ride height adjustment???? (Hershey)
There are no air shocks that will fit the front of a vette.
Oh and active suspension was out lawed in F1 in 1996.
Mar 6, 2004 | 02:54 PM
St. Jude Donor '03,'11
Re: Cheap method for front ride height adjustment???? (SCCACFC)
exactly, thats why i said i'm gonna modify the rears or find some others that are close.
if it doesn't work, i'm only out a pair of shocks and my time.
Mar 6, 2004 | 03:19 PM
I know there are air shocks with a bayonete top mount . As for the bottom mount you can certainly modify the existing through bolt mount to turn it into something that will bolt up. If you really want to go this route it can be done.
Mar 6, 2004 | 03:24 PM
Re: Cheap method for front ride height adjustment???? (norvalwilhelm)
bags don't belong on vettes
Mar 7, 2004 | 11:38 AM
550
i put 1.25" rubber spacers under mine.
raised front 1"
cheap & effective
Mar 7, 2004 | 09:05 PM
Re: Cheap method for front ride height adjustment???? (Matt Gruber)
Quote:
550
raised front 1"
cheap & effective
i ran that way for a while. didn't like it. The spring seemed to rub in the pocket and you can't get it back low for racing.
Mar 8, 2004 | 10:04 AM
does the lower front make it win when racing?
Mar 9, 2004 | 11:17 PM
nope it just looks cool.
Mar 10, 2004 | 05:19 AM
the air shock idea is :cool:
make a mounting plate, if necessary
Mar 10, 2004 | 11:02 AM
Cruise-In III Veteran
St. Jude Donor '05
Re: Cheap method for front ride height adjustment???? (81' Corvette Guy)
80lb bags of concrete will lower the car pretty good for cheap :jester
Mar 10, 2004 | 11:20 AM
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Cheap method for front ride height adjustment???? (SmokedTires)
They now make a shock / air spring (bag) combo. I think it's called 'shockwave'. It's made for the front end of lowered trucks.
I had the same idea about using air bags for adjustable suspension. Then the shockwaves came out and I left the idea when I saw the price.
Mar 13, 2004 | 03:29 PM
or a big block :lol:
1970 ,
1987 ,
adjust ,
adjustment ,
c3 ,
corvette ,
front ,
height ,
l6014 ,
performance ,
raise ,
ranges ,
ride ,
toe ,
vette
