Speedometer Gear ?
Old Mar 7, 2004 | 12:34 PM
Indy Year 25's Avatar
Indy Year 25
Default Speedometer Gear ?
I am replacing the plastic speedometer gear in the in the 4 speed transmission on my 68. The old gear cam out easily, the new gear will hardly fit through the hole in the transmission. I have to wiggle it back and forth while pushing on it to get it into the hole.
Is this normal?
Old Mar 7, 2004 | 04:46 PM
Indy Year 25
Default Re: Speedometer Gear ? (Indy Year 25)
Anyone noticed this?
Old Mar 8, 2004 | 07:27 AM
Indy Year 25
Do I have the wrong gear? I bought the orange gear from the Chevy dealership.
Old Mar 8, 2004 | 07:51 AM
Paul L's Avatar
Paul L
You're not getting a response so I will give this a try. There is a break point between 22 and 24 teeth where the drive gear as well as the driven gear has to be changed. Most cars I have seen use the 20 or 22 tooth driven gears. The orange gear has 25 teeth. So if you removed a 20 or 22 tooth gear you will have to replace the drive gear as well. Please see attached.
http://members.core.com/~faldrich/speedo.htm
Old Mar 8, 2004 | 08:38 AM
Fevre's Avatar
Fevre
My guess is the new gears barely fit through the hole while the old gears are slightly worn so they slide in and out much easier.
Old Mar 8, 2004 | 02:46 PM
djcwardog's Avatar
djcwardog
How did it feel once installed? How many teeth different is your new gear? Did you also replace the O-ring on your gear housing? I have a collection of speedo gears that I used to correct my car's speedo. I am happy with it now.
Old Mar 8, 2004 | 06:05 PM
Indy Year 25
Default Re: Speedometer Gear ? (djcwardog)
Thanks for the responses!
I guess maybe I mis-spoke. Instead of saying the gear barely fits I should have said I have to force the gear through the hole in the transmission case.
I haven't actually pushed it in all the way. I have been waiting to hear from others that have change the gear to see if this was normal.
The old gear was also an orange one, and the previous owner told me that is what I need. He also said he thought he had wiped out the gear shortly after installing it.
djcwardog, did you experience a tight fit with any in your collection?
To Speedometer Gear ?
