Rear Suspension Tools
Old Mar 9, 2004 | 08:06 PM
Oldguard 7's Avatar
Oldguard 7
Default Rear Suspension Tools
Other than Ecklers, where can one purchase the tools necessary to work on the rear suspension on a C-3 vette?? Spindle Installation, Rear Spindle Bearing Puller, Rear Spindle Press, Spindle Knocker, and Rear Spindle Set Up Tools. Im sure Ecklers marks up the prices by at least20%
Old Mar 9, 2004 | 10:13 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Re: Rear Suspension Tools (Oldguard 7)
:lolg:You can buy chairs for this even at Walmart these days. :lolg:
[Modified by cardo0, 9:14 PM 3/9/2004]
Old Mar 9, 2004 | 11:13 PM
hawgn68's Avatar
hawgn68
Oldguard,
I'm currently doing the same job on my '74. I'm sure I'll probably get flamed and loose my posting rights here, but I'll tell you the tools I've used successfully on my '68 and '73 road race car.
For a spindle knocker I use an old spark plug socket and a strong hammer
For the bearing puller, I use a harmonic balancer puller
To install the new outer bearing, I use the old one and a 2" pipe around the spindle and a stong hammer
For the set-up tool, I use sandpaper to turn down the spindle to slip fit the inner bearing (exactly the way the front outer bearing works)
You can then tighten the spindle nut to your own spec for preload/runout/endplay.
Just my $0.02 (but it works)
Good luck.
Jim
To Rear Suspension Tools
