HYD. ROLLER CAM from hyd. flat tappet
Old Mar 13, 2004 | 08:10 PM
comp's Avatar
comp
Default Re: HYD. ROLLER CAM from hyd. flat tappet (comp)
NEW TWIST do i have lobe to use mech. fuel pump :confused:
Old Mar 13, 2004 | 08:17 PM
PatsLs1vette's Avatar
PatsLs1vette
which cam are you using?not all gm rollers have a lobe for it.
Old Mar 13, 2004 | 09:28 PM
comp's Avatar
comp
Default Re: HYD. ROLLER CAM from hyd. flat tappet (patsnitrovette)
:banghead: i don't have the cam here now to have someone check the numbers as to spec's, OH well i still should be ok on the lifters,dog-bars &
the spider :smash:
