BB plug wires advice
Old Mar 16, 2004 | 10:20 AM
runamuck's Avatar
runamuck
Cruise-In V Veteran
Senior Member
Default BB plug wires advice
I am having trouble keeping the plug wires from burning up.(to close to headers) Wires are 8.8mm and have a straight 4" long boot to the plugs. This boot is burning due to close proximity to the header. Any advice would be appreciated. Engine is 454ci. 1971 Wires are ACCEL :mad
Old Mar 16, 2004 | 11:18 AM
zwede's Avatar
zwede
Default Re: BB plug wires advice (runamuck)
I had the exact same problem. First of all, I tried every accell wire they make and every single one burned, even with boot protectors. My conclusion is that accell uses inferior boots.
My solution: Borg warner select wires. They are spiral core and the boots are high quality, unlike accell. I found them at pep boys of all places.
Then I got a set of boot protectors, the kind that slip over the boots made out of some fiberglass material.
Haven't had any problems since.
Old Mar 17, 2004 | 01:03 AM
LT1driver's Avatar
LT1driver
Default Re: BB plug wires advice (zwede)
NAPA has boot protectors for $18 for two.
Old Mar 17, 2004 | 10:23 PM
WeasleVette454's Avatar
WeasleVette454
I had the same problem with my Accel 8.8's ....until I bent them a little. Since the boots are straight, they ran too close to the headers. One actually arced and caused my engine to miss terribly. I got replacements from Jegs (not cheap) and bent them a bit to clear. Problem solved.
Weasle :D
Old Mar 17, 2004 | 10:45 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
:seeya Jacob's Electronics with Ceramic Boots... :yesnod: :thumbs: :steering:
Old Mar 23, 2004 | 03:51 PM
LS-5 71's Avatar
LS-5 71
Default Re: BB plug wires advice (Intimidator454)
I went with the Taylors w/45 degree boots. Works great on big block. Every set of Accel wires I've owned were junk/poor quality.
To BB plug wires advice
