Changing Seat Covers
Old Mar 16, 2004 | 09:01 PM
HankB1's Avatar
HankB1
Default Changing Seat Covers
Has anyone changed their own seatcovers?
How difficult is it?
Any special tools needed?
Old Mar 16, 2004 | 09:22 PM
DMONSVETTE's Avatar
DMONSVETTE
Default Re: Changing Seat Covers (HankB1)
You might want to check out this link.
http://www.corvettemagazine.com/2001...s/seatspg1.asp
:seeya
Old Mar 16, 2004 | 09:34 PM
HankB1's Avatar
HankB1
Default Re: Changing Seat Covers (Ed T)
Thanks men !!!
This really helps !
It doesn't look like a difficult job, just tedious. :steering:
Old Mar 17, 2004 | 08:10 AM
Ybnormal's Avatar
Ybnormal
Not that hard to do at all...just did mine over the winter and did both seats in a weekend.
YBnormal...drive a vette :smash:
Old Mar 17, 2004 | 08:25 AM
Edzred72's Avatar
Edzred72
I changed my covers and foam a few weeks ago and used the links listed above as refrence. Take your time...seperate all the clips and hardware to determine how many and what goes where. I had to order an extra package of hog rings cause I wanted to use more than recomended. Made my own clip pulling tool out of a coat hanger. Do yourself a favor and buy the spring loaded hog ring pliers. Makes it a snap to install the rings.
Good Luck
Eddie
Old Mar 17, 2004 | 08:38 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Changing Seat Covers (Silvr77)
Take your time and be sure to take notice of the length of the retainers that go from the cover to the metal wires. Also notice where the retainers are located at along the listing of the original covers so you can put them back in the same location on the new covers.
Old Mar 17, 2004 | 09:04 AM
80TPIVette's Avatar
80TPIVette
I did mine and installed new seat foam too. I used the 4 inch pleat foam. It looks waaaay too big to fit on the seat pans, but it does. The hog rings aren't too difficult to attach, but the thing I found was the biggest PITA was putting the seats back in the pans. The seat backs were the hardest. You have to attach one side and then hold it from coming out while you press and pry the other side into the retainers. I also found that the hooking rails in the seat bottom foam isn't buried far enough down. When I hooked the hog rings to it, it didn't really pull the seat cover down that tight. They still turned out nice for my first time. I'm happy with them and that's all that matters.
To Changing Seat Covers
