Technical question : header Flange
Mar 21, 2004 | 10:52 PM
Re: Technical question : header Flange (Guru_4_hire)
posting to get the thread in synch w/the clock
Mar 21, 2004 | 11:15 PM
Cruise-In IV Veteran
Cruise-In V Veteran
Does anybody know the design of the header flange?
I know that they are roughly in this configuration
O--OO--O
But I need to know what the distance between centers are on all 4 ports, and how far the bolt hole centers are from the center of the ports.
I am trying to make my own drawing of a header flange.
Does anyone know where I could get this information?
Mar 21, 2004 | 11:36 PM
You could measure it?
Or measure a gasket
Mar 21, 2004 | 11:52 PM
Cruise-In V Veteran
Re: Technical question : header Flange (427V8)
And dont most gaskets come as seperate peices now?
Mar 22, 2004 | 12:34 AM
Real gaskets like Felpro etc don't...
Here are some measurements off a copper gasket I have
Mar 22, 2004 | 12:40 AM
Cruise-In V Veteran
Hmmmm thanx.
I think I am going to goto Advance auto and see what I can buy.
I dont understand how a 1 5/8 tube would fit around that port and still avoid that bolt hole
[Modified by Guru_4_hire, 12:41 AM 3/22/2004]
Mar 22, 2004 | 03:43 AM
Cruise-In V Veteran
Well I went to Advance auto
The holes are 6 3/4" from center to center on each side
with 1 3/4" in between the 2 center holes.
Mar 22, 2004 | 08:36 AM
Cruise-In V Veteran
the forum says Gdiana posted but I cant see it. Hmmmmmm
Mar 22, 2004 | 12:39 PM
Look up /\
So you didn't believe my numbers???
Well at least you got the same values :crazy:
