Does this look right to you guys?
Old Mar 21, 2004 | 10:49 PM
GDaina's Avatar
GDaina
Default Re: Does this look right to you guys? (70BBvert)
posting to get the thread in synch w/the clock
Old Mar 22, 2004 | 05:19 AM
70BBvert's Avatar
70BBvert
Default Does this look right to you guys?
Assembling the top half of the engine this afternoon. Well trying to. One of the coolant passage holes in the head gasket doesn't line up exactly on the block. The hole is off set about halfway. Is the normal? It's a 70 454 block, felpro gaskets, part # 1017-1.
Jim
Old Mar 22, 2004 | 06:35 AM
Steve's74's Avatar
Steve's74
Jim,
Just pulled the heads off my 1974 LS-4 yesterday. It's the first time they have seen the light of day since orignal assembly back in 1974. My block (numbers matching) has the coolant passage in the same location as yours, but the original head gasket (steel) has the passage blocked off (no hole). I also have in hand the listed FelPro valve grind gasket set which is part # HS 8180 PT-5 and lists for every BB from '65 thru '79, and it has the passage blocked. Are you sure you didn't pick up a gasket set for a Gen V engine ("91 and up)? I haven't seen any of those apart, but they do have different coolant passages.
Steve
Old Mar 22, 2004 | 06:49 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Does this look right to you guys? (Steve's74)
* Will not work on Mark V blocks
thats what that part number says
Old Mar 22, 2004 | 06:58 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Does this look right to you guys? (patsnitrovette)
is there a mating hole in the head? if not, it's most likely not a problem although I'm not 100% certain. If the head is blind in that spot the only problem you will most likely have is corrosion of the head surface in that spot.
Old Mar 22, 2004 | 07:52 AM
70BBvert's Avatar
70BBvert
Default Re: Does this look right to you guys? (Twin_Turbo)
I double checked the part #s 7 1017-1 is correct for a 70 454. These came in a full gasket set, Felpro 2805 I think. Took one head back off, two bolts only finger tight, & there is a hole in the head that they line up with exactly. Must be that way from the factory, offset coolant passage holes.
Thanks guys - got it all bolted together, well the heads anyway :)
Pat IIRC a 70 454 is a Mark IV. Mark V is a newer block, 91 up I think.
[Modified by 70BBvert, 7:55 AM 3/22/2004]
To Does this look right to you guys?
