81 evap system question
Old Mar 21, 2004 | 10:47 PM
GDaina's Avatar
GDaina
Default Re: 81 evap system question (gravismaximus)
posting to get the thread in synch w/the clock
Old Mar 22, 2004 | 06:26 AM
gravismaximus's Avatar
gravismaximus
Default 81 evap system question
on my 81, i just took off the evap canister and my question is this. the line coming from the gas tank to the canister, i have plug it , will that build presser from the tank causing my tank to burst? or what other problums may it cause. no computer---not stock carb :flag
Old Mar 22, 2004 | 06:37 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
nope should not be a problime
Old Mar 22, 2004 | 08:05 AM
rjones2979's Avatar
rjones2979
8th Gear
Sorry that will cause a big problen. As the tank is empited , it needs air so the tank will not colapse. Like wise when the tank is full on a hot day it needs room to expand. Very risky.
Old Mar 22, 2004 | 08:27 AM
Armstrong's Avatar
Armstrong
Couldn't he just use a vented gas cap if he wants to plug the line???
Old Mar 22, 2004 | 08:57 PM
gravismaximus
Default Re: 81 evap system question (Armstrong)
could i just no tplug the apor line then, or how about the vented cap idea?
Old Mar 23, 2004 | 03:31 PM
Willis's Avatar
Willis
I just unplugged my cannister from the carburetor and haven't had problems. I did not plug the hose, just tucked it away. My cannister was deteriorating and pushing crap into the carburetor, I cleaned it out three times in one week. Unplugged the cannister and haven't had to clean it since.
Old Mar 23, 2004 | 09:35 PM
weendoggy's Avatar
weendoggy
Fuel caps are threaded and they don't make a vented cap in that style. You'd have to "modify" it yourself. Here in CA. you have to have it all operational to pass emissions, even the vapor canister. It would seem that there is some problem that is allowing fuel to build up in the cansiter.
To 81 evap system question
