Steering Column Removal - Help Needed!
By the way, it would be a good idea to search the forum for steering column info and go the the papers Jim Shea has written on this stuff. He's the real guru and they are mucho helpful.
http://www.corvettefaq.com/redir.asp?site=612
http://www.corvettefaq.com/redir.asp?site=606
I really appreciate your help.
I looked at the links but am still confused as it appears to be the clutch linkage bracket (I have a 4 speed) that won't allow me -
#1 to pull the plate which is against the firewall (on the engine side) out towards the engine compartment far enough to remove the plate. (I have removed the 2 bolts inside the car on the inside plate.
#2 Even with this plate removed will the hole in the firewall be big enough to allow this bracket to fit through the steering column hole in the firewall or does this bracket need to be somehow removed??
I have attached a photo taken from underneath the car.
As detailed ditections as you can provide me are appreciated.
Thanks again,
Jay
here is the plate when removed
once the plate is removed ther is a large "pear" shaped hole in the firewall/footwell to allow the sterring colum AND the Ignition Key Lockout arm ( i think that is what its called) to be removed.
here is a tech paper on a Hydrobooster install. there is several steps listed on how to remove the steering colum. https://www.corvetteforum.com/techti...=190&TopicID=3
hope this helps
and BTW
welcome to the forum
cheers
chad
[Modified by 71'AirStrike, 8:46 AM 3/23/2004]
Look closely at the Steering Column Installation Diagram http://www.corvettefaq.com/redir.asp?site=606
First detach the transmission backdrive cable #2 from the lever on the lower end of the steering column. You do this by removing the cotter pin #5 and the washer #6. You can leave the cable attached to the mounting plate (M). Then remove the two nuts (R) that hold the steering column to the firewall. You should be able to pull the cable mounting plate back from the firewall. This will uncover the hole in the firewall where the steering column comes through. You will note that the hole has an oblong shape (you can see part of the shape right next to washer (P)). The lower steering column lever will slide right through that area of the hole.
A couple other hints. Detach your clutch pedal push rod from the Z-bar. This will allow the Z-bar to rotate toward the mounting plate, releasing the tension on the heavy clutch pedal return spring. Do this before you detach to two nuts inside the car.
Good luck,
Jim
