Transmission Trouble
Old Mar 26, 2004 | 01:08 PM
tom_red_76's Avatar
tom_red_76
Default Transmission Trouble
Hello all,
I just replaced the filter and pan gasket on my 76 Turbo 400. I still had it on jack-stands and was just having it idle while shifting into each gear. it did fine until i tried to shift from revers to park. it was grinding big time. it would grind and then go to park. any ideas? :confused: While i was doing this i don't have the half shafts on. could that have anything to do with it? other than that there is nothing else off right now. Any help is appreciated.
-Tom- :smash:
[Modified by tom_red_76, 12:09 PM 3/26/2004]
Old Mar 26, 2004 | 01:50 PM
viperjesse's Avatar
viperjesse
Default Re: Transmission Trouble (tom_red_76)
Was the driveshaft still turning when you went to park? If so it's just like the car was still in motion. The parking paw will grind instead of engaging.
Old Mar 26, 2004 | 02:18 PM
redwingvette's Avatar
redwingvette
Default Re: Transmission Trouble (viperjesse)
:iagree: What you did is the same as trying to put it park while the car is still moving :nono: :nono:
Old Mar 26, 2004 | 02:38 PM
NHvette's Avatar
NHvette
Default Re: Transmission Trouble (redwingvette)
... luckily without the momentum of the whole car pushing on it.
Still a no no :eek: :seeya
Old Mar 26, 2004 | 02:41 PM
GTR1999's Avatar
GTR1999
Sounds like the parking paw slamming into it. were yo running hte car with the rear on jack stands? Hopefully you had the T arms at ride height to prevent damage to the Ujoints on the 1/2 shaft.
Gary
JBR's Avatar
JBR
Make sure your foot is on the brake, so the wheels are not turning.
Old Mar 26, 2004 | 02:46 PM
stpman's Avatar
stpman
Default Re: Transmission Trouble (JBR)
He said he doesn't have the half shafts in, there's nothing to stop the rotation.
Old Mar 26, 2004 | 03:01 PM
JBR's Avatar
JBR
Default Re: Transmission Trouble (stpman)
Sorry I should have read closer. :withstupid:
Old Mar 26, 2004 | 03:03 PM
GTR1999's Avatar
GTR1999
:eek: You're right, no 1/2 shafts then it has to coast to a stop
Gary
Old Mar 26, 2004 | 07:42 PM
tom_red_76's Avatar
tom_red_76
Default Re: Transmission Trouble (gtr1999)
Thanks guys for the responses. After i posted i started to think and realized the same thing you guys said i couldn't stop the rotation of the trans because i had no brakes. well now i know and wont mess with it till i get the half-shafts in. thanks to all.
-Tom- :seeya
To Transmission Trouble
