freeze 12
Old Mar 29, 2004 | 10:56 PM
LT1driver's Avatar
LT1driver
Default freeze 12
anybody ever use this stuff and if so what is you opinion on it? :confused:
Old Mar 30, 2004 | 02:07 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: freeze 12 (LT1driver)
Haven't used it, but if its the same stuff that I have seen that is made from Liquified Petroleum I would be afraid to.....
Old Mar 30, 2004 | 06:12 AM
Larry B.'s Avatar
Larry B.
Default Re: freeze 12 (LAvetteman)
R12 ,R134a, is what most shops are equipped to handle. So they won't touch a system tha has anything else due to cross contamination. Next problem is Freeze 12 is a blended refrigerant so as it leaks out (all sysyems do leak over time) ONE of the components leaks first due to smaller molecules. Now you cannot just top it off like you can with R12 or R134a. You would have to evacuate and recharge the entire system.to gbet the proper ratio . You are better of converting to R134a. It works fine.... My stock 69 keeps me cool even here in Florida.
To freeze 12
