BBC Install: Head bolst interfere with header flange?
Old Apr 3, 2004 | 03:29 AM
DREGSZ's Avatar
DREGSZ
Default BBC Install: Head bolst interfere with header flange?
Could I be this cursed?
I started installing the new motor.
It's been together before, but now it seemd the flange can't clear the head bolts, but maybe they need to bre turned
Old Apr 3, 2004 | 06:38 AM
MassVette's Avatar
MassVette
Default Re: BBC Install: Head bolst interfere with header flange? (Evan Ginsberg)
I had to contour-grind the Hooker flanges to clear the head bolts on the 502-
:yesnod:
Old Apr 3, 2004 | 08:13 AM
BB wowbagger's Avatar
BB wowbagger
When i switched to ARP bolts i had to grind the flange to make it fit.Theres more grinding if you use Studs.. :smash: :cheers:
Old Apr 3, 2004 | 09:38 AM
GDaina's Avatar
GDaina
I've never heard that before...I'm using Hooker Super Comps...2.125" tubes, and no problems with the bolts and flanges....are u using header bolts or std head 3/8" bolts?
Old Apr 3, 2004 | 10:11 AM
zwede's Avatar
zwede
Default Re: BBC Install: Head bolst interfere with header flange? (GDaina)
Same thing with my edelbrock aluminum heads. The deck is thicker on many aftermarket heads, especially aluminum and require clearencing on the header flange.
Old Apr 3, 2004 | 02:37 PM
DREGSZ's Avatar
DREGSZ
Default Re: BBC Install: Head bolst interfere with header flange? (zwede)
THe motor has been rebuilt, he must have used different head bolts.
Thes are stock heads and super comp sidepipe headers.
the bolt corners point toward the head and I was thinking "if I could just turn them so the flat side of the bolt was parallel to the head then the flange would slip in. But it doesn't seem like a good Idea to start turning head bolts.
So which would be better to clearence?
the header flange (very little material there), or the head bolt. even if it lost a corner, it would still turn.
I haven't touched this car in a year, so I've been off this board. Ive been building a C4 racecar but the car is all custom fab and the C4 boards haven't been that helpful.
link to pics below in sig
Evan
C4R, Vette Viper Challenge car http://community.webshots.com/user/wavslav
Old Apr 3, 2004 | 03:27 PM
GDaina's Avatar
GDaina
Daaaaaaah.... :banghead: :banghead: :banghead: I should read what is written.... :banghead: :banghead: :banghead: ....had to grind the flange as well to clear the head bolts.....
To BBC Install: Head bolst interfere with header flange?
