Problem with Turbo 350 trans
Old Apr 5, 2004 | 10:30 AM
tabbruzz's Avatar
tabbruzz
Default Problem with Turbo 350 trans
The car is short shifting the gears so it seems. At the track the tranny shifts from 1st too soon than basically shifts to 2nd than right to 3rd like a second later. In effect it seems like 2nd gear is useless. I just had a 2700 stall converter put in so perhaps this is a problem as well as it seems very very lose. Also, if I'm cruising at like 40mph and floor it the rpms will shoot all the way up and not shift. Basically the tranny seem to be slipping. Any ideas or opinions???
Old Apr 5, 2004 | 10:38 AM
JBR's Avatar
JBR
Default Re: Problem with Turbo 350 trans (tabbruzz)
You say when crusing at 40mph and punch it the rpms shoot up. Does the car go any faster? This does sound like it is slipping big time. :confused:
Old Apr 5, 2004 | 11:02 AM
tabbruzz's Avatar
tabbruzz
Default Re: Problem with Turbo 350 trans (JBR)
Nope.....Not faster at all....
Old Apr 5, 2004 | 08:25 PM
duntovlives's Avatar
duntovlives
depending on ur gears, the "flare" at 40 could be normal w/ a loose converter.
the up shift can be altered w/ the governor. there is a series of weights/springs that control upshift. it works "kinda" like a centrifical advance in a distributor.
although, as always, check to be sure your fluid is not burnt. and, lack of fluid could also cause a simular prob.
when stall increases, shifts do begin to act goofy. but, if it is without a dobt shifting into each gear, just at the wrong time, look to the governor for you answer.
~good luck~ brian
Old Apr 5, 2004 | 08:44 PM
Jvette73's Avatar
Jvette73
Is the kick down linkage or cable intact and adjusted properly? That could make a difference in short shifting.
Old Apr 5, 2004 | 09:17 PM
tabbruzz's Avatar
tabbruzz
Default Re: Problem with Turbo 350 trans (Jvette73)
The tranny is in good hands right now. I know that the govenor and kickdown cable will be checked. I hope it's not a bum converter.. Thanks for the responses guys......
To Problem with Turbo 350 trans
