Normal engine temp?
Old Apr 7, 2004 | 09:30 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Normal engine temp?
what's the normal operating temp for the C-3's 82s in paticular? mine is running @ 180-200, and it's not very warm out yet.. I don't know if the temp gauge is faulty, reading normal or what. is theree a way to check the temp guage?
Old Apr 7, 2004 | 09:32 PM
desi's Avatar
desi
Default Re: Normal engine temp? (Markm10431)
Sounds about right. Mine runs at 190, I have a 180 stat. Keep an eye on it for over 200.
Old Apr 7, 2004 | 09:43 PM
jetlag's Avatar
jetlag
Default Re: Normal engine temp? (desi)
Mine sometimes goes up to 210 usually is around 195-200, but it never goes over that.
Could it be because my engine is not stock and is modified?
[Modified by jetlag, 8:43 PM 4/7/2004]
Old Apr 7, 2004 | 09:46 PM
Markm10431's Avatar
Markm10431
Parrothead
Default Re: Normal engine temp? (jetlag)
only reason I am asking is because the flexible circuit board is damaged the only guages in the cluster that work are the temp , fuel and MAYBE the volts. I'm not sure about that one either cause it's always reading above 14
To Normal engine temp?
