C3 Visual ID guide
Old Apr 9, 2004 | 05:26 PM
lostpatrolman's Avatar
lostpatrolman
Default Re: C3 Visual ID guide (GaryS)
69 - only year with factory side pipes.
Old Apr 9, 2004 | 09:26 PM
70L46Conv4Sp's Avatar
70L46Conv4Sp
Default Re: C3 Visual ID guide (lostpatrolman)
70-72 Square exhaust tips with hole off center (outboard), 73 had centered hole.
Old Apr 9, 2004 | 10:08 PM
Rottenrob's Avatar
Rottenrob
Default Re: C3 Visual ID guide (70L46Conv4Sp)
Beginning in 70 rear of fenders flared slightly to reduce road rash -in response to owner complaints. Makes for an overall more muscular look in my opinion. :cheers:
[Modified by Rottenrob, 7:09 PM 4/9/2004]
Old Apr 9, 2004 | 10:41 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Re: C3 Visual ID Guide (kenko74)
Difference between 76 & 77. Console & heat /ac controls !!
:cool: topic!!!
Old Apr 9, 2004 | 11:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: C3 Visual ID Guide (DP77Vette)
The side marker lights are smaller on 68 and 69.
Old Apr 11, 2004 | 01:55 AM
achase's Avatar
achase
Cruising
Default Re: C3 Visual ID Guide (Eddie 70)
The front side marker lights have white lenses on the '68, and orange lenses on the '69
Old Apr 11, 2004 | 01:58 AM
achase's Avatar
achase
Cruising
Default Re: C3 Visual ID Guide (achase)
The '69's have the engine information on the center console while the '68's do not.
The '68's have a plain passenger side dash cover while the '69's have a map pocket.
[Modified by achase, 1:59 AM 4/11/2004]
Old Apr 11, 2004 | 02:03 AM
achase's Avatar
achase
Cruising
Wheels on the '68 were 15 x 7", while the '69 used 15 x 8".
Old Apr 11, 2004 | 02:13 AM
Twin_Turbo's Avatar
Twin_Turbo
82: First year to offer opening "hatchback" rear window option. "Cross Fire Injection" above front fender vents.
The hatchback was only installed on CEs and not even an option on the others. IT's was CE exclusive, if you see one installed on a non CE they are using the aftermarket kit or someone parted out a CE.
