Rear Glass Trim
Old Apr 17, 2004 | 08:26 AM
TRUE-DUALS's Avatar
TRUE-DUALS
Default Rear Glass Trim
Could someone give some advice on how to remove the metal trim around the rear glass on my 80. I would like to clean it up and repaint it. I see there is a little slide clip joining the two pieces together but I don't want to dammage the paint or trim while removing it. Thanks
Old Apr 17, 2004 | 09:08 AM
terry82's Avatar
terry82
Default Re: Rear Glass Trim (TRUE-DUALS)
i would try the local body shop.they do it all the time .they could take it off for you or they will tell you how to .i repainted mine on the car .
Old Apr 17, 2004 | 02:17 PM
TRUE-DUALS's Avatar
TRUE-DUALS
Default Re: Rear Glass Trim (terry82)
ttt
Old Apr 18, 2004 | 09:39 PM
CF6873's Avatar
CF6873
You will need a windshield clip tool. You can buy it at most auto parts stores. It releases the moulding from the clip. Good Luck, Craig
Old Apr 19, 2004 | 01:30 AM
Riley's Avatar
Riley
Default Re: Rear Glass Trim (CF6873)
I went to an auto glass shop and they lent me the tool. It looks like a flat T that you slide under the trim to release the clips. If you have the right tool it makes it an easy job.1 min and your on your way. :party:
Old Apr 19, 2004 | 09:07 AM
Torcher's Avatar
Torcher
Default Re: Rear Glass Trim (Riley)
:iagree: When I did the trim on my 80, I just drove it to the glass shop and they did it for me in a matter of seconds... no charge. It really is simple, you just need the correct tool to do it.
:thumbs:
[Modified by Torcher, 9:08 AM 4/19/2004]
Old Apr 19, 2004 | 11:25 AM
6318's Avatar
6318
Default Re: Rear Glass Trim (Torcher)
strong fingernails work too!
Old Apr 20, 2004 | 11:35 AM
TRUE-DUALS's Avatar
TRUE-DUALS
Default Re: Rear Glass Trim (6318)
Thanks everyone. I'll try it this weekend
To Rear Glass Trim
