Msd ignition problem
Old Apr 17, 2004 | 12:58 PM
Deep sea vet's Avatar
Deep sea vet
Default Msd ignition problem
Is anyone runnign a Msd ignition with a series 6 ignition box. It looks like everything is hooked up right but I can not get the car to fire I did the test to see if the ignition is working I get spark to the ground. then I hook it back up and the car just cranks. any info would help.
Warren :confused: :confused:
Old Apr 17, 2004 | 01:48 PM
thebruce's Avatar
thebruce
Default Re: Msd ignition problem (Deep sea vet)
I had the same problem-- I could get a spark to ground from the box, but nothing at the plug. Turned out my coil was dead.
Good luck!
