Heater Core Help
Old Apr 20, 2004 | 04:15 PM
'69 silver BB's Avatar
'69 silver BB
5th Gear
Default Heater Core Help
Have a '69, 427 coupe, NO A/C. Anti-freeze leaking a bit through the heater inside right, not much, but a lot under the right side outside, soaked up the heat shield material. Heater hoses on firewall not leaking outside. Anyway, to get to the inside heater core, I have to remove the right dashboard panel and the center console panel. I've removed all the screws and the vent handle but the rside panel won't come off. Anybody know if there is something behind the panel that must be removed? Any other advice on the leak problem is appreciated!
Old Apr 20, 2004 | 04:19 PM
Paul L's Avatar
Paul L
Default Re: Heater Core Help ('69 silver BB)
This is a much easier way to do that job.
Two beer and one hour job.
[Modified by paul67, 4:26 PM 4/20/2004]
Old Apr 20, 2004 | 04:23 PM
Fevre's Avatar
Fevre
Default Re: Heater Core Help (paul67)
:iagree: took mine through the firewall, just make sure you take it with you to make sure you get the right replacement, first one i got from the corner parts store was wrong.
Old Apr 20, 2004 | 05:15 PM
Gordonm's Avatar
Gordonm
Default Re: Heater Core Help (Fevre)
:iagree: That is the way I did mine.
Old Apr 20, 2004 | 08:23 PM
sjr1971's Avatar
sjr1971
'69 stick with tour plan. The core isn't that bad to get out. The rt panel's Astro vent might be holding you up. There's a wing nut that holds the tube in. It's at the 12 o'clock position on the tube towards the kick plate POA but doable. Also behind the kickplate is a bolt holding the birdcage rod. THE ROD MUST BE REMOVED. Other bolt behind Inst cluster. 4 nuts on the firewall hold the heaterbox in.
Old Apr 25, 2004 | 12:30 PM
'69 silver BB
5th Gear
Default Re: Heater Core Help (sjr1971)
Thanks '71, thats some advice I can live with. I'll get back into the job soon.
Old May 5, 2004 | 08:30 PM
Mike Mercury's Avatar
Mike Mercury
hey guyz; I'm doing the same with the wifes 1973 (350 w/AC). From the pics... it looks like you took it out from the engine bay side. Am I seeing this correctly???
Did anything need be removed from inside the cockpit?
Any additional hints are welcomed.
Old May 5, 2004 | 10:51 PM
1970 Dave's Avatar
1970 Dave
Default Re: Heater Core Help (Mike Mercury)
Mike--I believe that with A/C, you must go through the inside--a PITA--akin to giving yourself a root canal-- I found it easier to remove the passenger seat as it gave me much more room--a good idea to have new replacement core pressure tested before installation.
Old May 5, 2004 | 11:44 PM
lowvette's Avatar
lowvette
Default Re: Heater Core Help (1970 Dave)
What forces an A/C heater core to go through the inside?
I need to replace my heater core (1977) and the car was originally equipped with A/C. When I installed the 383 engine, I took out the A/C compressor, compressor bracket, various A/C lines and the condenser. Do you think there's still something attached to my heater core that will require going through the inside? I did not remove the VIR, which is close to the heater core compartment.
Old May 6, 2004 | 04:06 PM
FeedVaal's Avatar
FeedVaal
Default Re: Heater Core Help (lowvette)
It's the presence of the A/C stuff that forces inside removal, so you should be fine. I, on the other hand, get to go at it from the inside this weekend. :smash:
Old May 6, 2004 | 10:37 PM
Mike Mercury
Default Re: Heater Core Help (FeedVaal)
well; I guess I do it the hard (inside) way then :sad:
Old May 7, 2004 | 12:31 AM
lowvette's Avatar
lowvette
For some reason, these photos remind me of my wife's C-section. Sorry, just left OT. :jester
From the other posts, it looks like I'll be able to operate on my Vette the same way. Sorry for those having to go from inside.
Old May 7, 2004 | 07:46 PM
sjr1971's Avatar
sjr1971
JEEZZZ . C section? Cuttin thru the fire wall is an aborti_n. How do you repair the damage? The g-d dam-ed core removal IS NO BIG DEAL. A PITA but very doable. Don't butcher the fire wall over this. Jumper out the heater. If you want to know how to R&R the core email me. I've done it. Heater now works well. Firewall still in 1 pce. Gotta go now, the ether,the ether......
Old May 7, 2004 | 08:00 PM
sjr1971's Avatar
sjr1971
Just noticed the dates. This has been a joke from day one Right ??
Old May 8, 2004 | 07:41 AM
Paul L's Avatar
Paul L
No cutting needed. The core is behind the fan motor cover.
Old May 8, 2004 | 10:20 AM
Juliet's Avatar
Juliet
Here are some pics of the core removal on an AC 70. I paid to have this job done. :D http://www.corvetteforum.net/c3/juli...tCore_orig.htm
Old May 8, 2004 | 08:57 PM
Garson's Avatar
Garson
I just removed my core in a non air car from the firewall side. It was a piece of cake. It will take about 10 times longer to clean up the sealer from around the box that it took to take the core out.....
Garson
To Heater Core Help
