Heater control unit
Old Apr 24, 2004 | 03:24 PM
ddaveyboy@home.com's Avatar
ddaveyboy@home.com
Default Heater control unit
Hi guy's
Just wondering if anyone has run across this same problem with this product. I purchased an after market heater control unit for an AC 1977 model from contemporary corvette. initailly it worked ok and then it started leaking vaccum from the little selector valve. I phoned them and they said to send it in for warrenty. They sent me the same unit back (I'm asuming they changed out the vacuum valve) and now it leaks vacuum on all selections except in the off positon. Not impressed. I tested the unit on the bench with a vaccum tested ,and it does in fact leak in all positons except off. Is the offshore stuff really this bad???Feedback??
Dave :confused:
