just bought a 79 ...the rear deck and some other pieces are in need of new paint ....what should i use on the rear deck ...sand it down and use regular paint? it seems to be fiberglass not plastic.
any help will be appreciated...
joe
Re: help with rear deck refurb on 79 corvette (wildone)
Are you talking about the "package tray" inside the car? If you are, you could be starting a big job!!! Not 'cause that piece is difficult to do, but, depending on your interior colour, you could end up re-dying your entire interior!!!
It's not that tough. Remove the part to be "painted" and clean thoroughly, then clean it again, then wipe down with a solvent (mineral pirits or the like) and paint it with a flat black plastic paint. (SEM is often recomended here). You shouldn't sand the interior parts, as you could wipe out the moulded "texture" GM gave it... If you have any other Q's, don't hesitate!
