ZZ4 Engine Specs
Old Apr 29, 2004 | 11:29 PM
jamiejamison's Avatar
jamiejamison
Default ZZ4 Engine Specs
Anyone out there have the torque (bolt) specifications for the ZZ4 engine. Putting mine back together with new pistons. Thanks.
Old Apr 30, 2004 | 07:25 AM
theandies's Avatar
theandies
Default Re: ZZ4 Engine Specs (jamiejamison)
I have seen the torque specs before but it was a long time ago and I cannot find them now. Try calling Sallee Chevrolet or Jim Pace and maybe they have them. I looked on their web sites but could not fine the specs. I'll keep looking, maybe I have them in a notebook somewhere.
Old Apr 30, 2004 | 08:49 AM
6318's Avatar
6318
Default Re: ZZ4 Engine Specs (theandies)
If you haven't got an answer by this evening I'll check my install book...
Old Apr 30, 2004 | 11:57 AM
theandies's Avatar
theandies
I found this for you:
This may help:
Camshaft retainer bolt/screw, 106 in.-lbs
Camshaft sprocket bolt/screw, 18 ft.-lbs
Connection Rod nut, 20 ft.-lbs = additional 55 deg./.006" bolt stretch preferred.
Crankshaft balancer bolt/screw, 63 ft.-lbs.
Crankshaft balancer pulley, 35 ft.-lbs.
Crankshaft Bearing cap bolt/stud, inner: 70 ft.-lbs Outer: 65 ft.-lbs
Crankshaft rear oil seal housing bolt, 11 ft.-lbs.
Cylinder head bolt/screw, 65 ft.-lbs
Distributor bolt/screw, 25 ft.-lbs
Drain plug, 15 in.-lbs
Engine block oil gallery plug, 15 ft.-lbs
Engine front cover bolt, 97 in.-lbs
Exhaust manifold stud or bolt, 26 ft.-lbs
Flywheel bolt/screw, 65-70 ft.-lbs
Front cover, 10 ft.-lbs
Intake bolts (first pass), 15 ft.-lbs
Intake bolts (second pass), 35 ft.-lbs
Oil filter adapter bolt/screw 17 ft.-lbs
Oil level indicator tube bolt/screw, 106 in.-lbs
Oil pan assembly (corner bolts), 15 ft.-lbs
Oil pan assembly (side rail bolts), 97 in.-lbs
Oil pan baffle nut, 30 ft.-lbs
Oil drain plug, 15 ft.-lbs
Oil pump bolt to rr crankshaft cap, 66 ft.-lbs
Oil pump cover bolt, 80 in.-lbs
Spark plug, 15 ft.-lbs (Tapered Seat)
Starter motor bolt, 35 ft.-lbs
Valve lifter guide retainer bolt, 18 ft.-lbs
Valve rocker arm ball stud, 50 ft.-lbs
Valve rocker arm cover bolt, 106 in.-lbs
Water pump bolts, 30 ft.-lbs
Kink = http://www.sallee-chevrolet.com/Disc...tml?1057682651
Old Apr 30, 2004 | 11:57 PM
jamiejamison
Thanks, thats exactly what I needed. JamieJ
To ZZ4 Engine Specs
