Another Stupit Plug Wire Question
Old May 4, 2004 | 07:37 PM
Kevin Mason's Avatar
Kevin Mason
Default Another Stupit Plug Wire Question
OK, after noticing that my plug wires were arcing, I got a set of Taylor 8mm plug wires. So far so good.
However, on returning home, I noticed that I bought a universal, "cut-to-fit" set. That's great, inasmuch as that way I can make sure that my wires are just the right length, but how do I cut, strip and crimp the new wires?
The instructions Taylor included did not tell me much that was worth knowing or that I did not already know.
Old May 4, 2004 | 08:13 PM
Gordonm's Avatar
Gordonm
Default Re: Another Stupit Plug Wire Question (Kevin Mason)
I like the cut to fit. You can route them how you want with out any big loops or stretching the wires. There is a wire crimp tool that really helps out. This will make you have a secure connection. Beg, borrow, or buy one it will make the job go easier.
Old May 4, 2004 | 08:18 PM
Kevin Mason
Default Re: Another Stupit Plug Wire Question (Gordonm)
I assume by "beg, buy, or borrow" you meant "steal"?
Seriously, can this tool likely be bought at the parts store where I got hold of the wires? Presumably not too much $$
[Modified by Kevin Mason, 7:19 PM 5/4/2004]
[Modified by Kevin Mason, 10:09 PM 5/4/2004]
Old May 4, 2004 | 10:09 PM
Solid LT1's Avatar
Solid LT1
NAPA stores carry an electrical line under the Belden brand. The Belden wire connector/plug crimper is very good, the MSD plug wire tool is one of the best I have ever used but, it is over $40 as I remeber (maybe you can find a shop willing to rent theirs.) Most universal plug wire kits have crimping tools that you put into a vise and hit with a hammer, some are OK. You can cut off the boots of the old plug wires and tape the new ones onto the old wire to pull them back towards the distributor instead of taking 8 HRS to do an install like I did with my first Vette (if you want the wires in the stock location, I like them there!)
Old May 4, 2004 | 11:10 PM
Kevin Mason
Default Re: Another Stupit Plug Wire Question (Solid LT1)
Thank you, Solid and Gordonm, keep the suggestions coming.
Old May 5, 2004 | 12:02 AM
Ironcross's Avatar
Ironcross
There is a proper crimping tool available just for plug wires. It WILL handle all types of the brass connectors, including 90 degree. It really does a correct job of connecting ends as factory. NO vices or needle nose stuff, it`s a special ignition wire plyers and available at most major auto parts stores. Not everyone will know about these however as they are a little pricy but a must for proper cutting and crimping. Belding, B/W, and Standard Ignition companies have them in their wire catalogs under the tool section. :thumbs:
Old May 5, 2004 | 11:12 AM
Kevin Mason
Default Re: Another Stupit Plug Wire Question (Ironcross)
Thanks, Ironcross. Would you recommend just returning the universal kit and just going with a standard issue sbc plug wire kit?
Old May 5, 2004 | 11:59 AM
Ironcross's Avatar
Ironcross
As Long as they are cut to the right length and premium grade, discount junk will probably not be correct. :thumbs:
To Another Stupit Plug Wire Question
