Intakes and cams
Old May 7, 2004 | 11:41 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Intakes and cams
I have a 9:1 compression engine, and I am thinking about using a XE268 cam.
What I have now is completely unacceptable for the street. The single plane and the cam I bought it with is making life difficult, so I want to scrap the cam, and get a decent dual plane intake, while keeping my holley 650DP.
so I am looking for a idle - 6000rpm intake or so. The edelbrock performer would be nice, but they dont come made for a squarebore, I guess you need some kind of adapter plate. The RPM airgap would be cool, but I dont want to shell out 200 bucks. I also considered the holley 300-36 which I guess is a knock off of the LT1 intake, but that is pretty tall. Taller in the back than the stupid wieand 7546 single plane I have. The holley 300-48 would be good but it has the EGR provision which I dont want, and is pretty tall.
Any Ideas?
Old May 7, 2004 | 01:48 PM
Brettmc's Avatar
Brettmc
Default Re: Intakes and cams (Guru_4_hire)
Bought a cam from the bottom of the page? What is it?
Brett :thumbs:
Old May 7, 2004 | 02:55 PM
Corey_68's Avatar
Corey_68
Default Re: Intakes and cams (Brettmc)
I ran the CC 268 in my 327 w/a a 650 DP and I LOVED it, graat midrange and sweet lope at idle. :cheers:
Old May 7, 2004 | 03:50 PM
Guru_4_hire
Cruise-In V Veteran
Brett :thumbs:
huh? :confused:
Old May 7, 2004 | 04:00 PM
Brettmc's Avatar
Brettmc
Brett :thumbs:
huh? :confused:
You know, the cams listed at the bottom of the seller's page. The BIIIG ones.
Brett :thumbs:
Old May 7, 2004 | 04:02 PM
Guru_4_hire
Cruise-In V Veteran
Ohhh I dont know whats in it, all I know is it doesnt like driving around at street RPMs.
Old May 7, 2004 | 04:09 PM
marshrat99's Avatar
marshrat99
I'm running an XE262 and the Edelbrock Performer EPS intake on my 79. The intake comes either spread or square bore. :cheers:
Old May 8, 2004 | 08:48 AM
Ganey's Avatar
Ganey
Performer does work w/ a Holley. You could use the XE-268 & EPS.
Old May 8, 2004 | 10:10 AM
Guru_4_hire
Cruise-In V Veteran
Default Re: Intakes and cams (Ganey)
i will see what i can get cheap from ebay
To Intakes and cams
