Need help with gear lube.
Old May 10, 2004 | 11:19 PM
kmckiou's Avatar
kmckiou
Default Need help with gear lube.
I just recently bought a '73 454, 4 speed, and I was planning on changing the gear lube for my positrac, what would you recommend I use?
Thanks.
Old May 11, 2004 | 12:12 AM
FEDX's Avatar
FEDX
From: A high school diploma fixing what a college degree broke TN
Default Re: Need help with gear lube. (kmckiou)
I don't have any real preference on the lube,I'm using Havoline right now.But what is of primary importance is not forgetting to add GM posi lube,or similar substitute.You'll know it when you drive it if you forget :D
Old May 11, 2004 | 12:24 PM
pws69's Avatar
pws69
Mobil 1 Gear Lube + 1 can of GM Posi Additive
Old May 11, 2004 | 01:39 PM
Fevre's Avatar
Fevre
Default Re: Need help with gear lube. (pws69)
:iagree:
Old May 11, 2004 | 04:51 PM
GTR1999's Avatar
GTR1999
90 wt "old school" gear oil- any brand with 1-2 bottles of GM only limited-slip additive.
gary
To Need help with gear lube.
