ignition problem
Old May 11, 2004 | 09:17 PM
jetech's Avatar
jetech
Default ignition problem
The other day while driving my 77 quit running. I replaced the coil and it still wouldn't start, next I replaced the ign module and the car started and ran fine for a while. It then shut off again but I kept trying to restart it this time and it did restart. When I got it home and pulled the dist cap I found the vac adv weights overlapped. I don't know if this would cause the car to die but both times I was at highway speed. I drove it today with no problems but was wondering if anyone else had this happen. What is the probability of the coil pick up going bad? I would think it either works or it doesn't. Also I replaced the coil and module with Napa parts, are these any good? :seeya
Old May 11, 2004 | 11:09 PM
comp's Avatar
comp
Default Re: ignition problem (jetech)
you may have loose weight bushings, I like NAPA parts, they also sell a bushing kit :thumbs:
