newbie question.... power steering pump pulley
Old May 20, 2004 | 01:51 PM
jack_b's Avatar
jack_b
2nd Gear
Default newbie question.... power steering pump pulley
Hi Ya'll, I come from a BMW background. The only american experience I have is rebuilding an auto tranny in my friend's Impala SS. But my girlfriend's dad gave her a california 76 stingray......
The power steering pump was leaking badly and I thought it best to replace it. Well, I don't know how to get the pulley off the old one. I used one of my 6" pullers and I ended up deforming the pulley. So now I need to know where to get one. What's a good place to buy corvette parts from? The local autozone can't help me. Does anyone have a good used p/s pulley FS?
TIA
Derek
76 stingray originally from socal now Boston MA
And a bunch of vintage bimmers.
Old May 20, 2004 | 02:28 PM
Crash80's Avatar
Crash80
Default Re: newbie question.... power steering pump pulley (jack_b)
I would start here:
http://www.angelfire.com/mo2/GruhalaEnterprises/
Gary might be able to help you and if not can probably steer you in the right direction.
You might also try here:
http://www.corvettejunk.com/
Good luck in your search.
Old May 21, 2004 | 12:16 AM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Re: newbie question.... power steering pump pulley (CVT4ME)
Parts stores sell a puller for the pulley. I took out the power steering pump and mounted it on a vice and used an impact wrench to loosen the pulley. You can't remove it with a rachet.
Old May 21, 2004 | 05:29 AM
DMONSVETTE's Avatar
DMONSVETTE
Default Re: newbie question.... power steering pump pulley (feb18blacksunday)
Air Impact wrench got mine off. :yesnod: :seeya
Old May 21, 2004 | 08:49 AM
jack_b's Avatar
jack_b
2nd Gear
Default Re: newbie question.... power steering pump pulley (DMONSVETTE)
Thanks guys, but the pulley is mangled now. I need a new one. Anymore ideas?
Old May 21, 2004 | 09:02 AM
mrvette's Avatar
mrvette
Jack, IM me I MAY have a pulley off my '72 here, well may be the same pulley, not sure, I think mine is a press fit, have to go check maybe later today, not now....
GENE
Old May 21, 2004 | 10:07 AM
wcsinx's Avatar
wcsinx
Default Re: newbie question.... power steering pump pulley (mrvette)
GENE
Nope, design changed in '75. You can get a brand new one from Zip for $34. Part Number SC-405
Old May 21, 2004 | 07:57 PM
sjr1971's Avatar
sjr1971
You don't need to pull the wheel. Have the press line brazed, if it doesn't leak your down town. If it still leaks get a new one [,$100]
Old May 21, 2004 | 10:53 PM
R. Bruno's Avatar
R. Bruno
I had exactly the same problem (mangled) Just drop by the local junkyard. They will have a million power steering pumps with pulleys on them. I bought a pump and pulley for $25, took off the pulley, and returned the junkyard pump as my core (not perfect match for the Vette pump but the counter guy at Autozone won't notice or care.) Then you keep your old Vette pump and you have a spare. :cheers:
BTW, sorry to hear that you come from such a shady background (BMW) but we won't hold it against you. :D
To newbie question.... power steering pump pulley
