What Is The Difference.....
Old May 29, 2004 | 10:41 PM
Richard Cooper's Avatar
Richard Cooper
Default What Is The Difference.....
.... between a radiator clutch fan and a stationary fan? I want to replace my clutch fan because it has some play in it and I was wondering if I could put in a spacer and just a regular fan. Thanks.
Old May 29, 2004 | 11:01 PM
77stingray's Avatar
77stingray
Default Re: What Is The Difference..... (Richard Cooper)
The fan with the clutch will usually spin if you try to while the engine is off. The regular or stationary fan will not spin at all. The clutch fan is more effectient usually maintaining more horsepower than the same car with a regular fan. If you can , try to keep the fan with clutch. Good Luck!
Old May 29, 2004 | 11:36 PM
79 vette's Avatar
79 vette
The clutch on the fan is bolted on it is a solid piece if you have some play it is most likely the bearings in the water pump. :seeya
To What Is The Difference.....
