From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Low fuel light - doing "odd" things.
My 1980 has a low fuel light, that up until lately, has worked just fine.
But lately, it will come one and go off for no reason at all. I could be at a full tank of 1/4 tank and the light will turn on and stay for a while, and then go back off.
The gage reads correct - or pretty darn close. I thought that the low fuel light got it's information from the sending unit the same as the gage does. If so, how can the low fuel light be coming on when the gage still reads above 1/4 of a tank or more?
Better check it out!!!!!! When I did my dash over in my 77 the resistor in the low fuel circuit shorted out and I couldn't shut the car off. It started to smoke and melt. I was lucky enough that I hit it with my screwdriver and it fell out of the larger circuit board attached to the guage cluster, and the engine shut off.
My light turns on and off as the fuel sloshs around in the tank. I don't remember how low the tank has to be before it starts happening tho. Maybe some of the contacts have some corrosion on them and it has changed the point at which it come on.
On my '80 you would have to get it very low to see the "sloshing effect" you describe. I think it starts to glow when there is only 2 gallons left, if I was told correctly. I drove my car down that far only once to see if the light worked. I was about to give up thinking it didn't when it slowly started to glow. The further down it got, the brighter the light. BSeery's problem is a strange one indeed.
CI 6-7-8 Veteran
Re: Low fuel light - doing "odd" things. (CVT4ME)
That is the way mine used to work. I don't think it's a problem with the sending unit as that would affect the gage as well. I would blame the sending unit if I had just filled it and it showed empty and the light was on.
I am going to look for a new little light circuit, or yank it.
They are nearly impossible to find, you would think that there would be enough taken from wrecks but I had to search long and hard to find a working unit. I did pay top dollar for it (I told corvette central who had one left in their used department to include it without asking the price first)
I will sell it for the right amount, I'm not giving it away
BSeery, you might contact TheoUK about this. Seems like I remember him building a pretty simple circuit that replaced his low fuel light. He also somehow made it so that it would come on a bit earlier than the stock rig. I don't remember the details but I am sure he would share his info. with you.
The fact that at that time I posted mine was working fine, now I have problems with mine and find that post while doing a search through Google.
Ah, how history comes back to bite us in the ****.
Hello folks.
Here's the link to the adjustable low fuel light, all credit to Dale, the guy who did this design, he helped me a lot via email. http://www.corvettefaq.com/fuellight/
almost the same as the stock GM design, except the adjustability factor!
Those transistor numbers should be fine to use as direct replacements in your GM board, if you don't fancy actually making a new one.
CI 6-7-8 Veteran
Re: Low fuel light - doing "odd" things. (theoUK)
Hello folks.
are those pictures of your car in that list of instructions? I wanna know who's really cool looking dash that is.
Sadly no! I can't lay claim to those - they're pretty cool though eh?
All of that page was put together by a guy named Dale, and those are pics of his car (79, I think)
I exchanged a lot of emails with him as I worked my way through building the fuel light circuit board he designed. He was most helpful (and very patient with my lack of electronics knowledge!)
He sent me some more photos of other parts of his car during his body off resto - as you can imagine he does very good work. I believe he built his own rack and pinion setup - steeriods beware!
I think he once used to frequent the forum as dale79, but I haven't seen any sign of him for a while....
