Solid spicer U-joint (the aftermath)
Old Jun 24, 2004 | 08:24 AM
American Boy's Avatar
American Boy
Default Solid spicer U-joint (the aftermath)
I broke a u-joint cap in half last week that causes a vibration and here is what I found...the bolts that hold the metal strap was loose. Those 1980-82 model use 12 points tiny bolts to secure the strap and from now on, I will use locktite on them to prevent a disaster.
Stephan
Old Jun 24, 2004 | 10:38 AM
BKbroiler's Avatar
BKbroiler
Default Re: Solid spicer U-joint (American Boy)
Thanks for the follow up info.
Old Jun 24, 2004 | 10:46 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I check my half-shaft bolts all the time (both ends each side) and regularly find that there's a bit of movement. Drives me nuckin' futz!
Old Jun 24, 2004 | 11:24 AM
SpyderD's Avatar
SpyderD
Default Re: Solid spicer U-joint (SanDiegoPaul)
Same ujoints are on the drive shaft, best check them too. The drive shaft to differential bolts are fun since you can't really see them.
They always make me nervous, rebuilding the rear end earlier in the year I was thinking "these little screws are holding the whole rear end together"?
[Modified by SpyderD, 8:26 PM 6/24/2004]
Old Jun 24, 2004 | 01:36 PM
American Boy
Default Re: Solid spicer U-joint (SpyderD)
Thanks for the idea, I didn't even thought about those ones on the drive-shaft...where my head at??????
Stephan
To Solid spicer U-joint (the aftermath)
