Msd Ignition Setup
Old Jun 26, 2004 | 03:46 PM
hirevroller's Avatar
hirevroller
Default Msd Ignition Setup
I have a stock L48 Motor and I will be installing a eps intake manifold, eps carb. Performer heads and matching cam. But I want the msn setup which distibutor and box should I be using.
Thanks Guys
PS just got my Eagle Alloy 203 wheels 15" all four for $500 cdn HEHE
Old Jun 27, 2004 | 11:49 AM
hirevroller
Default Re: Msd Ignition Setup (hirevroller)
Please guys I have no clue.
Old Jun 27, 2004 | 12:00 PM
zwede's Avatar
zwede
You want the 8360 distributor and 6420 box (6AL). Then you'll need a coil like the 8203.
Old Jun 27, 2004 | 12:09 PM
billlambeer's Avatar
billlambeer
Default Re: Msd Ignition Setup (zwede)
The coil and wire come in a kit. 8474
Old Jun 28, 2004 | 01:13 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What year is your car? If you have a distributor with a tach drive for the tachometer you will need the MSD tach drive distributor. If you have a later year car that came with an HEI and an electronic tach you would could use another MSD distributor
To Msd Ignition Setup
