Old header temp mystery solved...
Old Jun 26, 2004 | 07:20 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Old header temp mystery solved...
Some of you might remember that I posted about a year ago that one of my header pipes would always show a different temperature than the header pipes on the other 7 cylinders... (measured with a laser temperature gauge).
I finally found the reason... The header temp is actually the same on all cylinders, but the chrome on pipe number 1 is shinier than the chrome on the other pipes.. The reflection of the pipe actually caused a false reading... I measured on the side of the pipe where the chrome is more dull.. and I got the same reading as on all the other 7 cylinders.. I didn't know that the laser gauge wouldn't work correctly on reflective surfaces
[Modified by GrandSportC3, 7:21 PM 6/26/2004]
[Modified by GrandSportC3, 7:22 PM 6/26/2004]
Old Jun 26, 2004 | 07:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Old header temp mystery solved... (GrandSportC3)
We use these type temp sensors at work sometimes. The ones we work with have an adjustable emisivity feature. This allow for different types of surfaces to be read. Most of the ones that you and I can buy, are not adjustable. Good find. BTW, the one I have I got at sears and gave $30-40 for it. Works good for what I want to do.
Old Jun 26, 2004 | 08:02 PM
GrandSportC3
Default Re: Old header temp mystery solved... (Eddie 70)
That's a good price!!
Old Jun 26, 2004 | 08:43 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Got a part number or discription on that one?
Old Jun 27, 2004 | 05:23 PM
shoptek's Avatar
shoptek
Are you playing with my IR gun???????
I thought I lent it to Mr. Wonderful........
You're gonna owe me another 9v battery
Remember when we ordered chicken wings with"hot" sauce and then actually measured their temp??? The waitress thought we were nutz
Old Jun 27, 2004 | 05:28 PM
GrandSportC3
Default Re: Old header temp mystery solved... (shoptek)
To Old header temp mystery solved...
