71 corvette odometer
Old Jun 27, 2004 | 09:20 PM
lstill's Avatar
lstill
Cruising
Default 71 corvette odometer
guy's ,need some help.i have a 71 sunflower yellow coupe.....everything works on it except.....the speedometer registers but the odometer doed'nt register the miles you travel....have a 72 also that does the same thing.....anybody encountered this and what is the fix?....thanks Larry
Old Jun 28, 2004 | 08:24 AM
Larry B.'s Avatar
Larry B.
Default Re: 71 corvette odometer (lstill)
common problem http://www.corvettefaq.com http://www.corvetteinstrumentservice.com
Old Jun 28, 2004 | 08:33 AM
Gordonm's Avatar
Gordonm
Default Re: 71 corvette odometer (Larry B.)
I rebuilt the head on mine. Fairly easy to do but it is a common problem. Most likely one of the gears is stripped or broken. Most of the vendors have kits available to rebuild the heads for both tach and speedo.
To 71 corvette odometer
