St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Electric Antennas
I am going to install an electric antenna on my 70. Just wondering if anyone has done this and is there anything special that needs to be done such as reinforcing the antenna mount etc....
An antenna works with a ground plane. This isn't a problem with metal cars because the body acts as the ground plane. On our cars there is a metal piece under the rear fender that acts as the ground plane. This piece must be grounded to the frame. You will probably have to drill out the hole a little on the ground plane to fit the larger antenna base of the electric antennas. If you don't want to modify the original ground plane you can get a thin piece of aluminum and cut it to the same size and shape as the original. Mount the antenna through the ground plane and tighten up the retaining nut on top of the fender. Not too tight or you'll crack the fiberglass. Once you've done this you will have to fabricate a support for the bottom of the antenna to prevent it from moving around. You can do this with some pipe strapping that you can get from a hardware store if the antenna kit doesn't supply it. Once that's done all you need to do is run the antenna wire, a hot and ground electrical line and a remote control line to the unit. It's not a bad job but you're working in cramped areas so set aside plenty of time. Good luck.
I bought mine from Mid America. If fit fine, and works fine without mods. You won't need the ground plate that was being used by your original ant. This one will mount up at the top through the body, and has a strap to bolt to the frame right below the hole. No need to drill the frame, there is a bolt hole right here you will need it.
Run the wiring back with the other wires along the DS door well. I hooked mine up to a toggle switch instead of the radio, that way if I am listening to CD's the antena will stay down.
Reception is great, better than most if not all antenas on cars I have owned in the past.
Got it working. But, I wired as in the instructions and it goes up with the key and down when the key goes off. Nice and quiet too. Not at all lik the one in my wifes Acura. That thing is loud.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
When this one hits the upper limit it goes click click. Turn the key off and it is quietly going down and then the lower limit, click click. The whole motor is contained in a rubber type surround. I was actually nicely surprised by it after listening to the one in my wife car.
i installed a switch on my antenna so i can fully control it going up...so if it won't automatically go up when i turn the key..only when i want to listen to FM, I'll hit the switch and it goes.. IMO, i just can't stand the look of an antenna up on a sports car..
