Have new springs and have discovered the spring compressor I have won't work. Has anyone ever used the "floor jack & chain" method? Good idea? Bad idea?
Am going w/ the stock replacements. (Eckler's #34786). I drove a car similar to mine with the 460's and felt they were a bit too harsh. Imagination? Coulda been... Anyway will also be replacing all 4 shocks with KYB's, so the ride should be somewhat improved.
BTW: RF spring on car now is broken at 2nd coil from bottom. NOT good.
